Results 1 to 10 of 11
Thread: Clutch pedal has no feel and pushes to floor effortlessly; causes?
    Jan 2014
    Adelaide
    Hi guys
    After driving on a highway for 40 mins at 90kmh the clutch pedal went straight to the floor, had zero feeling and I was unable to change gears. I checked the reservoir which was full however there was little to no movement on the slave cylinder. I assumed the fluid had boiled and sat the car for 20 mins. Feeling returned to the pedal with the engine off, but as soon as started it become quite soft again, which I assume was due to the power assist. Pushing it all the way to the floor I was able to select a gear and drive home.
    Today the pedal is as soft as yesterday. I will replace the slave cylinder, rubber line, flush and bleed. Apart from this what else could lead to the above symptoms? Also, how do you check the clutch in a GB TB42; I'm told they don't show signs of slipping and just let go.
    FYI - the car is off the road while I also try to resolve large coolant leaks.
    Clutch booster may be leaking? But then again, it should just be extra heavy then. How close is the exhaust to the clutch lines and slave cylinder? Radiant heat will give you grief on the clutch too.
    Master cylinder.
    Yeah I would replace master and slave cylinders at the same time.
  5. #5
    Jan 2014
    Adelaide
    The master was done not all that long ago. The exhaust is very close to the slave on GQ's.
    Annoyingly Repco sell the slave but not the rubber clutch line which seems only available online.
  6. #6
    Sep 2011
    adelaide
    18 Post(s)
    Was the master rebuilt or a new one, if rebuilt then recheck as there may be an internal problem
  7. #7
    Jan 2014
    Adelaide
    New I believe; it was before I owned the vehicle. Perhaps 3 years old but only 15k.
    I have to order half my parts online as they're not stocked here. I'm hoping to have everything by mid next week. Will start with a new slave and flush and bleed.
    Sent from mTalk
  8. #8
    Legendary dom14's Avatar
    38 Post(s)
    Use a bleeder like this. Saves lot of trouble.
    http://www.ebay.com.au/itm/Hand-Held...IAAOSwA3dYZiCZ
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  9. #9
    Sep 2011
    adelaide
    18 Post(s)
    I see your location is Adelaide , where about`s , north, south,east or west. I`m down Christies way and spent 45 years on the tools in the brake and clutch game, so if your close enough I may be able to have a look.
  10. #10
    Jan 2014
    Adelaide
    Thanks, i bought one a while ago in prep for the brake flush. Looking forward to finally using it.
    Thank you for the offer however I am Semaphore way. If my order from Patrolapart ever turns up I'll swap out the slave and slave line and see what happens. I was under the impression the adjustment was on the slave/fork but i have just read it is fixed and done from behind the pedal; fingers crossed for a nice learning curve!
