Results 21 to 30 of 37
Thread: GQ Auto Lock Up
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Just thinking about it , it's more than likely in fourth just locked or unlocked , if someone knows what prevents the box when cold from changing up to final overdrive that will be the answer .
    Interesting as I don't believe the a/t oil temp has anything 2 do with gear changes and o/d
  2. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    GQtdauto (7th January 2017)
  3. #22
    Legendary GQtdauto's Avatar
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Weird but true , cutting wire 22 on the TCU has the same affect of waiting for the box to heat up when cold ie it stops the box from changing into the final gear or as I suspect on mine it either turns the torque lock on or off allowing it to kick up .
    Can't buy a temp gauge for tranny oil in my one horse town neither Repco or supercheap sell them or anyone else so will order from fleabay.
  4. #23
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    There is a temperature switch inside the transmission which the TCU uses to help control it. Generally the transmission will not go into 4th or O/D until it's up to temp. Lockup should occur after that at around 80km/h.
  5. The Following 2 Users Say Thank You to Chaz For This Useful Post:
    GQtdauto (7th January 2017), NissanGQ4.2 (7th January 2017)
  6. #24
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Feel like I've hijacked rippers thread so sorry ripper maybe they can move these comments?
    So Chaz if I'm reading it right you're saying what I've done does lock the converter ?
  7. #25
    Aug 2010
    17 Post(s)
    Yes we did sorry @ripper ( good 2 see your still floating around here ), I have moved everything over 2 this new thread for you @GQtdauto
  8. The Following 2 Users Say Thank You to NissanGQ4.2 For This Useful Post:
    GQtdauto (7th January 2017), ripper (7th January 2017)
  9. #26
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks rotaredom, didn't want to wreck rippers excellent torque lock thread .
  10. #27
    Dec 2016
    Northeast Victoria
    41 Post(s)
    I'm wondering if I'm the only one stupid enough to try this mod , although I have seen a lot of posts where people have asked basically the same question.
  11. #28
    Sep 2010
    Adelaide
    If wire 22 goes to the converter locking solenoid on a GQ, then cutting it will prevent the converter from locking. You need to put power onto the solenoid to lock it.
    If you have cut the wire, try putting power onto it when you drive from second gear up and you will feel the difference. Or better still run a wire from the cig lighter socket through a switch and to the wire that you cut that goes into the transmission. Then you will be able to switch it on and off as you need, but remember never to shift into park or neutral with it switched on.
  12. The Following User Says Thank You to Chaz For This Useful Post:
  13. #29
    Aug 2010
    17 Post(s)
    Lock up is common you can even buy kits online I believe
    @Chaz ( good 2 see your still lurking on here ) is well know for his write up on the Lockup trans switch for his GU Nissan Patrol 3.0Di
  14. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
  15. #30
    Dec 2016
    Northeast Victoria
    41 Post(s)
    Thanks Chaz and nissangq4.2 , will rig something up , switch I put in has extra terminals so I will just join the two sides of 22 wire one side and a positive the other side making sure I know it's off then go for a spin and activate in second gear .
    As for buying a torque lock kit or making one using rippers design .
    If what I'm doing won't work I'll follow ripper or buy one but I'm happy enough with the way mine works in all other ways .
