Page 717 of 1057 FirstFirst ... 715716717718719 ... LastLast
Results 7,161 to 7,170 of 10566
  1. #7161
    Would have 2 be well over 6 months ago, once the originally battery died from sitting there, I kinda gave up on it all
    Before it was built *L*
    Is yours still on the road Ben???
    Been nearly 2 months since I started mine =[
    Haven't had money to put fuel in it. Going for a drive this weekend though and I'll take it.
    I've only driven 3000kms in it so far this year.
  2. #7162
    22 Post(s)
    Hasn't been on the road since 11th dec 2015
    96 GQ coil/Cab
    08 G6eT
  3. #7163
    Is anything happening with it?
  4. #7164
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    You got another play toy? or just been working 2 hard so not enough time 2 play???
  5. #7165
    22 Post(s)
    Nothing. They wiped their hands with it, because in the eyes of their insurer and likely the courts (which I have given up on because of the cost and time compared to getting another motor) , me(not a qualified mechanic) installing the motor into the chassis and fitting all the auxillary items caused the pistons/bore cleance to be set at 14 thou, not 25 thou and grabbing the bore, the crank to be ground out of square then evidence of that to be destroyed because requesting an inspection and report means machine, amongst other things. I should have gone with my gut and built the thing myself, atleast any failure will actually be my fault
    96 GQ coil/Cab
    08 G6eT
  6. The Following 3 Users Say Thank You to Ben-e-boy For This Useful Post:
    NissanGQ4.2 (29th December 2016), Rossco (29th December 2016), Yeti's Beast (24th January 2017)
  7. #7166
    22 Post(s)
    Yeah the g6et. I dont do big hours any more. Just perminent arvo shift Monday-Thursday
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  9. #7167
    Changed the rear diff oil after checking the oil cos pinion started leaking a bit. Was reasonably dirty hopefully doesn't give to much trouble if i can make it home to replace the pinion will be happy.
    Checked all other oils which were fine and replaced air filter. Pretty bad i know but hadn't changed it since the desert trip, it was pretty bad 😕. . .
  10. #7168
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Checked all other oils which were fine and replaced air filter. Pretty bad i know but hadn't changed it since the desert trip, it was pretty bad ��. . .
    New filter don't even clean It
    saw dust for the diff till you get home
    new oil will leak more, saw dust mate works every time in the oil
  11. The Following User Says Thank You to Sir Roofy For This Useful Post:
  12. #7169
    Quote Originally Posted by Sir Roofy View Post
    Haha banana peel, old used car salesman trick to quieten noisy diffs until customer is down the road!
    Gong him Red!!
  13. The Following 3 Users Say Thank You to Plasnart For This Useful Post:
    Sir Roofy (29th December 2016), Stropp (29th December 2016), Yeti's Beast (24th January 2017)
  14. #7170
    TRAFALGAR VIC
    35 Post(s)
    Yes but oil gets thicker with saw dust dead quiet then
  15. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Plasnart (29th December 2016)
