Page 713 of 1057 FirstFirst ... 711712713714715 ... LastLast
Results 7,121 to 7,130 of 10566
  1. #7121
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Installed new 80 Ch GME uhf radio and antenna
  2. The Following User Says Thank You to Bacho86 For This Useful Post:
    daggy (19th December 2016)
  3. #7122
    Is that all black above the spring, or is it just the way the pic was taken?
  4. #7123
    Mar 2011
    14 Post(s)
    The top whip section is black but there is a middle section above the spring that's silver -- pretty much sure they're are complete black options if you really wanted
  5. The Following User Says Thank You to Bacho86 For This Useful Post:
    jay see (19th December 2016)
  6. #7124
    Nov 2016
    Last night i finished a complete coolant system overhaul; drained coolant from the engine block as well as radiator. All new belts, new water pump, new fan, new hoses.... I was sorta dropping nuts before i turned it over thinking that i had forgotten to tighten things (even though i checked it 10 times); but it cranked over fine and just bled the system of air.
    Was so psyched i chucked in new LED globes aswell my misso got me.... i know some people don't think they're great but i'll run em for a while and see what i think of them...
    Big shout out to the guys on here who are always helping give tips or help when we get a bit stuck!
  7. The Following User Says Thank You to ToddD42 For This Useful Post:
    threedogs (21st December 2016)
  8. #7125
    Good tip if you're running a light bar is mask off and spray all antenna matt black.
    You would be surprised how much glare you get from white antennas
  9. #7126
    Quote Originally Posted by ToddD42 View Post
    give us some feed back on your LED globes, are they the ones with a fan/motor on them?
  10. #7127
    Expert Rip'n'Shred's Avatar
    Hunter Valley, NSW
    I agree with you there from first hand experience. I taped mine up with black electrical tape.
    GU IV 2006 4.2 TDi wagon
  11. The Following User Says Thank You to Rip'n'Shred For This Useful Post:
  12. #7128
    Quote Originally Posted by Rip'n'Shred View Post
    Even an alloy bull bar needs either black gaffer tape or carefully mask off
    a section and spray matt black again
  13. #7129
    Feb 2011
    Shed
    45 Post(s)
    Yesterday picked Troll up from the mechanic.
    Exhaust manifold machined.
    Found snapped stud, hence the manifold leakin(Bastard$%$# to get the snapped one out)
    Replaced radiator top tank
    Replaced split air intake duct $450 F@RK3N BUX!
    Supply fit fuel filter
  14. #7130
    Did some wiring work, nothing caught fire, total success, did some welding on rear bar, all good, total success, replaced power steering pulley with a duplex for hydraulic winch drive - didn't break anything, total success - something has got to change as I'm not used to this!
  15. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    AB (21st December 2016), BigRAWesty (21st December 2016), Cuppa (22nd December 2016), Plasnart (22nd December 2016)
