Valve timing is good. No dramas with the timing belt.
Dizzy is properly placed on TDC spot with number 1 cylinder.
Few more mods on the way
https://www.panthera.org/
Cheetah Outreach
Ignition timing was way off yesterday when I checked the timing. It was about 20 degrees advance.
That came out as a surprise, 'cos I thought it was lot less than that.
Cheetah Outreach
I've got it sorted out. A silly mistake of getting the correct side of the rotor tip mixed up.
Cheetah Outreach
NissanGQ4.2 (10th December 2016)
Hi Guys, I been using this type of spark plugs from the UK called Brisk High Performance Spark Plugs on my GU. August 2014 installed and car running great on both fuels , below is a ebay link . hope this helps cheers
alex
http://www.ebay.co.uk/itm/6x-Brisk-L...item568433581b
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
dom14 (21st December 2016)
