Results 1 to 10 of 14
Thread: 98RON & older engines
    Legendary dom14's Avatar
    38 Post(s)
    Hey Guys,
    I decided it might be better to use 98RON on mine(GQ RB30 carby, dual fuel).
    I thought ignition timing compromise between LPG and petrol can be set to a better minimum
    with LPG being higher octane than regular 91RON petrol.
    Is this a good idea?
    If so, do I need any "upper cylinder lubricant" or is it just an old wive's tale?
    Mine is a 1990 model GQ.
    Thanx
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    petrol wise no. at that age it should have hardened valves and seats(feel free to correct me on this one). i ran 95 ron in the old laser (carby 1989) i want further on a tank so it worked out cheaper than 91. but i had to re-tune it to suit the fuel.
  3. The Following User Says Thank You to garett For This Useful Post:
    dom14 (14th December 2016)
    Dec 2015
    WA
    5 Post(s)
    The RB30 is not an older engine, it came out in the Holdens as their first unleaded petrol engine, the upper cylinder lube is to compensate for the lack of lubricating lead in old engines built to run on leaded petrol.
    Graham
  5. The Following User Says Thank You to GeeYou8 For This Useful Post:
    38 Post(s)
    Quote Originally Posted by GeeYou8 View Post
    Graham
    Ok, cool. If I understood you guys correctly, I should just put 98RON and tune the ignition timing accordingly.
    That's it?!
    Thanx
    Cheetah Outreach
    Patrol Guru
    Jul 2014
    6 Post(s)
    Sounds right to me.
    Only consideration would be if/when you head out bush, 98 isn't always available. I keep mine on 91 for that reason, it's out bush too often to be bothering re-timing it every time.
    Also one of the reasons I've avoided turbo'ing it.
  8. The Following User Says Thank You to Throbbinhood For This Useful Post:
  9. #6
    Hi Dom. I was told by a motorcycle mechanic not to run 98 in carby engines. He said it leaves residue in the carby as the fuel/air mix doesn't ignite as hot as injected systems. So for my 1989 road bike its only 91 RON. I know totally different engines but the philosophy might be googleable.
    Gong him Red!!
  10. The Following User Says Thank You to Plasnart For This Useful Post:
  11. #7
    Expert UncleFrosty's Avatar
    Aug 2016
    Goldfields WA
    Thanks for pointing this out @dom14.
    I feel a 'speriment coming on for mine around town as I only used 98 on long trips, and hadn't considered I may be better off running it all the time due to dual fuel setup...
  12. The Following User Says Thank You to UncleFrosty For This Useful Post:
  13. #8
    Expert billyj's Avatar
    gordon
    @Plasnart if thats what he is telling you i suggest finding a new motorcycle mechanic.
    as to doms original question yes 98 octane will allow for a much better compromise setting between petrol and gas, as for remote travel you can get pretty potent octane booster additives which could be easily carried to give regular 91 octane a bump up if required
    the rb30 is/was designed as an unleaded engine (being an alloy head it has to have hardened seats) so is fine without the upper cylinder lube
    if you want to get the most out of it just bump the timing up on petrol until it pings under load then drop it back down by a degree or so
  14. The Following User Says Thank You to billyj For This Useful Post:
  15. #9
    84 Post(s)
    That is how I timed the engine after a mechanic changed out the timing belt and the engine was pinging under load. It was only after I had to renew the head gasket because a couple of fire rings had cracked, it was explained to me that silent detonation had caused the engine to run hot and caused the cracks. If I was to tune the engine to run properly on RON 98 I would get it dyno tuned, but that is just me.
  16. The Following User Says Thank You to mudnut For This Useful Post:
  17. #10
    gordon
    a dyno would the the perfect world way to do it but going a couple of deg back from the point of pinging shouldnt be a problem provided that the af ratio is right, if its running lean then it will be hot and burn things up
  18. The Following 2 Users Say Thank You to billyj For This Useful Post:
    dom14 (14th December 2016), mudnut (14th December 2016)
