Cheap shit bushes will do that. Use genuine or someone who makes bushes to suit patrols and their intended use especially if looking at castor correction bushes. Superior do a fairly good castor correction bush as do arb.
Urethane are rubbish too.
PeeBee (13th December 2016)
Hmm... sorry, I tried urethane in my last truck and I could not wait to get rid of them. I found them very hard hence not very resilient and the ride was crap.
The best think with suspension i have found for an off road vehicle is rubber.
Just my experience, but never agin.
Rainsey
Sent from my iPad using Tapatalk HD
Well guys, like most things, you only get the truth when you look and do something yourself. It wasn't until I saw the note from Ropes that something twigged, so I had a look at the rubber inserts myself and there is nothing wrong with them, 100% fine. The 'mechanic' at Pedders in Dandenong told me the pass side was totally rooted and collapsed. What it appears he saw was the rubber element metal insert that has a piece of rubber profile missing. So apologies for the waste of time.
PeeBee (15th December 2016)
Was speaking with BD today about parts arrival and gvm issues and found out Scotty has been taken to hospital, unsure how serious, but hope he recovers quickly. They don't expect him back before xmas.
One other thing, be aware the dipstick on the chev is held in place with silastic as a seal only, no clamp or threaded part. I have to change my sump and this little detail was disclosed when I could note work out how to pull the existing one apart. I guess it's a concern from a leak perspective as its below the oil fill line.
OK, have the dual vee pulley installed, bracket in place, belt sorted out and DCV mounted ready for the hose guy. Couple of picks. The DCV is mounted behind the winch, which gives good access for installation, direct to winch and at the right height for the reservoir. Hope this helps PhilDSC01710.JPGDSC01721.JPGDSC01727.JPG
Has anyone installed a 4L80E kit from Brunswick diesel? How did the kit go? Easy to fit?
Cheers,
Brad
