Page 711 of 1057 FirstFirst ... 709710711712713 ... LastLast
Results 7,101 to 7,110 of 10566
  1. #7101
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Installed my new JVC stereo and GME UHF.
  2. The Following User Says Thank You to Mc4by For This Useful Post:
    VK2FMIA (6th December 2016)
  3. #7102
    Big couple of weekends..
    Have installed reverse camera.
    Hooked up the dimmer on the head unit.
    Still need to sort the park brake hack so dvds work.
    Finally finished the lift..
    Love it..
    Well.. need to sort front towers..
    Resealed the light bar.
    Tightened front wheel bearings.
  4. The Following 2 Users Say Thank You to BigRAWesty For This Useful Post:
    Hodge (10th December 2016), jay see (11th December 2016)
  5. #7103
    Dont you just earth the park brake circuit out? Then dvds will work all the time. The hand brake switch is just a simple normally closed switch.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
    BigRAWesty (10th December 2016)
  7. #7104
    Advanced morton2478's Avatar
    Mar 2015
    Installed the new glow plug seals today thanks to mudski for the new seals but also found the injector seals leaking a job for the new year
    Sent from my SM-T530 using Tapatalk
  8. #7105
    Yea that's what I've read. Tapped the supposed trigger line to the earth but still no good..
    So gotta dig more on the unit to see that I have the correct line earthed
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    Installed my awning.
  10. #7107
    Removed the radiator for the forth time and added 9ml of oil to the viscous fan hub as my previous oil adjustment left the hub not engaging at all. So now I can you this at speed...Just trying to get the hub to engage and disengage at a satisfactory time.
    I also installed full manual free wheeling hubs to replace the auto hubs that I had converted to manual....And drank beer whilst doing this. Was a good day,...
  11. The Following 2 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (11th December 2016), Rossco (28th December 2016)
  12. #7108
    Patrol God Stropp's Avatar
    38 Post(s)
    IMG_1736.JPGIMG_1737.JPGNew diesel water separator and Ufi fan and hub, getting a bit tight under the bonnet now.
  13. The Following 2 Users Say Thank You to Stropp For This Useful Post:
    mudski (11th December 2016), Rip'n'Shred (20th December 2016)
  14. #7109
    Im keen to hear your thoughts on the UFI hub Stropp. Whether its engaged the whole time etc etc.
  15. #7110
    Well my DVD issue was the wrong wire..
    Found the manual.
    Then found the wire tagged park switch..... 😐
    Earthed it out and wholla.. DVD works..
    So now it's all up and working as it should..
