Page 41 of 136 FirstFirst ... 3940414243 ... LastLast
Results 401 to 410 of 1356
Thread: All Things Chev
  1. #401
    Quote Originally Posted by PBBIZ2 View Post
    OK, Chev conversion guys, what front springs are you running? I am after something thats around the 50mm lift so it does not attract the attention of the coppers, but more importantly must be able to take the weight of a 6.5 chev V8, hydraulic winch, ARB Bb and side rails and second battery. I am yet to weigh the front end, but your input would be greatly appreciated. I am running Dobinson 400kg coils with airbags on the rear, but not convinced necessarily on this brand for the front based on how they failed to hold their height even when unloaded.
    Guys, maybe you are not running coils???? Anyway I have the vehicle booked in on Dec 11 with Dobinsons to sort out the right front coils and try to resolve the bump stop issue. I was looking at bump stops on ebay but think I may need to go down the track of adjustable hydraulic or the sorts - any input appreciated. Has anyone had issues similar to mine of thumping the sump against the diff housing?
  2. #402
    Longtime Lurker Ropes's Avatar
    Oct 2010
    Madora Bay, WA
    Quote Originally Posted by peterc99 View Post
    Hi to all 6.5 Chev owners - please check proximity of crossover (exhaust) pipe to your starter motor - had mine die due to stator winding solder connection failing - apparently due to heat.
    Regards
    Peter
    Hi Peter, forgive me but it took me three days to read this thread in it's entirety and I can't remember when you had your conversion done, what sort of a time frame are you talking about in regards to this failure?
    Craig
  3. #403
    Oct 2010
    Madora Bay, WA
    Thumbs up
    Today I ripped the aux battery out from under the truck and fitted it up in the rear, in front of one of the drawers. I was sick of seeing high temps on the battery monitor due to its proximity to the exhaust. 49 degrees C on much of my last trip convinced me it was killing the battery and I wanted to move it. I am posting this here as it really is a specific thing to the Brunswick conversions as there is no room in the engine bay.
    Couple of pics.
    New battery location. I just used the same battery box as it was easier to mount than a tray.
    Shortening one of the drawers...
    Just used rivets to refasten the back of the drawer.
    Battery now sits right behind the Redarc BMS.
    Now have some re-wiring to do to complete the job. Some new lighting, compressor power, and a fuse block are being planned.
    Thanks heaps for the pictures and especially the reasoning why you did it.
    I wasn't particularly happy with the idea of putting the battery down under the vehicle when Scotty (BD) said they'd be putting it there, that coupled with the fact they said I also couldn't keep my current mandrel bent 3" exhaust because the battery needed to go there and now after reading here what their 3" exhaust systems are like.....
    I'll keep mine and they can leave the battery out for me to fit when I get the vehicle back.
    Craig
  4. #404
    Oct 2010
    Madora Bay, WA
    A/R- Aspect ratio of a housing attached to the turbo.
    Peter has changed his turbine housing.
    Its the way they measure the size of the housing. Generally the smaller the number the quicker it will respond but will be restrictive in higher rpm due to not being able to flow enough.
    I would be inclined to leave a 0.84ar turbine housing on a chev fitted with an auto.
    Ultimately I would bin the garrett and put a borg warner turbo on it instead.
    This might help too.
    23" STEDI Light Bar, ARB Twin High Flow Compressors, Full Length Alloy Roof Rack, Black Widow Jack and Shovel Holder, ABR-Sidewinder Dual Battery System, Small Barn Door Extension Bracket, Icom 400 Pro UHF, Safari Snorkel, Boost Gauge, EGT Gauge, Rear Cargo Barrier, Outback Rear Drawers, 33" Hancook MT’s, Dawes valve and Manual Boost controller, EGR block, 2” Lift, TJM Winch Bar, CampTrax 270º Awning, 12,000lb Winch, ARB 60ltr Fridge, ARB Front Air Locker, ARB Rear Bar/Dual Wheel Carrier, Rear Coil Tower Braces
    A work in progress
  5. The Following 2 Users Say Thank You to Ropes For This Useful Post:
    MB (1st December 2016), rainsey (1st December 2016)
  6. #405
    G'day Phil, mine came from the west massive coils all round. Not sure what brand mate, just know they were the thickest I've ever seen. Now I'm running Firestone bag coil replacements in the rear and Ridepro coils in the front. Coil replacements in the front were too much mucking around for Vic roads as they want sensors as safety features etc... I'm gonna have to reassess my front coils now too with a new bar coming hopefully after Chrissy. Please do keep us posted with what Dobinson's reckon although yours is GQ and I think most of us posting here at the moment are heavier GU's. Cheers mate!
  7. #406
    <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=70045"/><img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=70046"/> These are the damage areas. Ignore the last 2 images on previous message- could not remove them via editing
    G'day Phil, photos are hard with angles and such, it looks like the bolt & nut from your dif shield hit it and pierced through maybe?
  8. #407
    Yes, exactly, and the bolt body dented the pan itself. The stater motor hit the diff also and broke.
    Dobinsons are going to drop the springs out and also measure the required bump stop length the stop the diff hitting the sump etc as part of the exercise - not sure where and how I go to resolve the bump stop issue but will have to listen and asses what theysay I guess - BD simply don't seem to have come across this issue - which is bizarre.. The coils we are looking at are 19mm dia wire with 50mm nominal lift. The coils recommended by one of their distributors on ebay has been dismissed. Still jousting with BD about the replacement faulty starter and who is going to fit it - I am totally over this at the moment. I will let you know where it ends for sure.
  10. #408
    Couple of pics.
    Also for the gas blowers like me.
    Like this, think I will be pinching this idea if the battery and box isn't too tall.
  11. #409
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Behind the drawers I wouldn't worry about a box if it's a AGM or something
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  12. The Following User Says Thank You to lucus30 For This Useful Post:
    jay see (2nd December 2016)
  13. #410
    Apr 2016
    Shoalhaven
    Hi Craig, the Chev engine was put in 2.5 years ago, but don't wait that long if your crossover pipe is close to the starter - better to wrap heat shielding (double wrap)around crossover pipe adjacent to the starter to prevent any future problems. This could have failed on our Madigan trip - would have been awkward.
    Regards
    Peter
