Quote Originally Posted by PBBIZ2 View Post
First weekend away with the new motor - did not go well.
Got into Burgoynes without incident and stopped to have a look at the hut - car world not stat - battery appeared totally daed or at least it was sitting at 13.5V then turn the key - down to 4V - fark. Jump started it with a cable across to the aux battery - all going.
Drove over the hill to the next capsite, parked up then heard a hissing and splashing sound - oil pissing out of the sump. Checked further, 20 cent piece slot hole punched in the sump - lost about a liter of oil.
BD changed the coils and the ones they put in are sloppy and way too soft - coil went to full compression at about 1kph and came down hard on a mount bolt holding the front diff guard in place - fark
Popped bonnet and aircon belt had turned itself completely inside out on the pulley - how the hell can that happen?
Anyway, luckily had a slug of instant metal, so cleaned up the slash and fixed the hole. Starter issues just got worse and had a look at the belt but the mechanism to adjust the belt defies everything i have seen so far, so left that alone.
Rang BD on Saturday after climbing out of the valley to get phone coverage. They are organising a new starter motor and sump, out of Eagle Spares in Melb on Monday - will see how long this actually takes. I will have to have another chat with Scotty at BD about the belt though. Couple of shots attached. Going to weigh the front of the vehicle to match a set of coils correctly.
Engine itself runs hard and well, really happy. Fuel consumption way better that the overloaded 2.8 - approx 1/4 tank better for same k's. Have not filled it back up yet as cant rstart it when it stops at the moment.
Re the time it takes for Brunswick to supply parts, as some of you know I have been chasing an oil leak. Each time we think we found the cause Scotty at Brunswick shipped the respective part, air express via toll, had it on the east coast within 2 days.
Re the oil leak ... will post in my next post.
Re the air air con belt. BD put a sticker under my bonnet near the catch with a diagram as to how it all goes in... bloody handy.
Rainsey
Sent from my iPad using Tapatalk HD
