Page 186 of 220 FirstFirst ... 184185186187188 ... LastLast
Results 1,851 to 1,860 of 2192
Thread: AB's new GQ is finally here
  1. #1851
  2. The Following User Says Thank You to AB For This Useful Post:
    BigRAWesty (25th November 2016)
  3. #1852
    Thats interesting AB, who rebuilt your front diff? Wipe that clean mate and monitor it. Normally when the inner axle seal is gone it will weep and drip straight down, that looks like a build up of Grease not Diff Oil. a big seal leak will splatter the inside of the tyre too.
  4. #1853
    Definitely looks different to when mine was leaking from there. I had oil all over the inside of my tyre too.
  5. #1854
    Aug 2014
    Perth
    10 Post(s)
    My GQ wagon used to do that, don't believe there was any issue or the mechanics I were using didn't think there was anyways.
  6. #1855
    22 Post(s)
    Easiest way to tell if the front diff is bent is camber and the uneven wear on the tyres from that.
    The best way to check if the diff is bent is to strip it down and use an axle housing allignment bar.
    Something like this
    http://www.chassisunlimited.com/stor...s/ce-9905.html
    96 GQ coil/Cab
    08 G6eT
  7. #1856
    doesn't look like a major leak to me, very small hence the build of of gunk with dust n sh!t.
    As MR and Winnie said, a bad leak would be splatter your inner tyres too.
    P.S. you worry too much
  8. The Following User Says Thank You to Clunk For This Useful Post:
    MB (26th November 2016)
  9. #1857
    Yeah it is grease. But that was cleaned before.
  10. #1858
    Patrol God Stropp's Avatar
    38 Post(s)
    Clean it again 🙄
  11. The Following User Says Thank You to Stropp For This Useful Post:
    rusty_nail (28th November 2016)
  12. #1859
    483 Post(s)
    Luve ya mate, just drive the bastard :-) !!
  13. The Following 2 Users Say Thank You to MB For This Useful Post:
    jay see (26th November 2016), Rossco (26th November 2016)
  14. #1860
    Clean it again
    All clean...lol
    Even just turning the wheel grease comes back on the ball joint.
    Noticed that hub was pretty stiff to lock too.
    Cv issues?
