Ok, that may be or may not be the same thing.
The low rev grunting of the gearbox is fairly common in GQ Patrols.
I experience that in gears up to the third, though I can't remember hearing it on fourth and above though.
If the car body vibrates with that thing, then you may have something different related to pretty much anything in the
drive train, as well as suspension issues.
After driving the vehicle today, I realized that the vibrations were mostly felt at high revs. They seemed to have been getting worse. anyway, checked underneath this evening. Found that the bolts connecting the driveshaft to the rear diff were loose enough to be turned by hand. Going to tighten them up in a while.
