Page 47 of 50 FirstFirst ... 4546474849 ... LastLast
Results 461 to 470 of 498
Thread: Outback Ideas Recovery points
  1. #461
    483 Post(s)
    G'day John, thanks heaps for the last set of recovery points for our family wagon build mate, awesome gear they are ! Which ones of your models might suit/under a Millweld bar I'm dreaming of for my ute project?
  2. #462
    What year ute do you drive and what was the original motor??
  3. #463
    483 Post(s)
    Sorry John I just remembered Mill mentioning that to install my chosen new bar oneday that they cut something like 80mm off the chassis. Might be safest for me to raincheck the ute points until the bar is actually on, hopefully before next easter if coin can permit. Cheers mate!
  4. #464
    I dont think 80mm will cause a problem, happy to wait ,lol
  5. #465
    Oct 2010
    Old Bar, NSW
    I have recently had the front bar replace with this ARB unit, preferred another brand but it was not something I could do much about at the time.
    Any way when the panel beater put the recovery points on they were upside down / inside out, stuffed if I know how they managed it. Harrold Scrubie would have had orgasm's referring me to the authorities! They seriously impacted on my front approach angle!!
    The problem was there was no flat surface to get all 3 bolts in so they used 2 with a 25mm spacer on one!
    I took them off as soon as I got home and realised that to get them to sit correctly 3 x 25mm spacers were needed plus longer bolts. Some 40mm diameter aluminium rod cut and drilled to suit now has them sitting right.
    My question, is this acceptable to mount them like this?
    Some pics that might help explain.
    The new bar
    Mounting recovery points
    edit; The damn pics are all upright in the file but do this when linked, any help out there?
    Macca
  6. #466
    Aug 2014
    Perth
    10 Post(s)
    Hey threedogs I've got a 2004 ST 4.2 Coil Cab-Chassis with a Nissan Factory bull bar on it can you advise what recovery points suit and the cost delivered to 6164
  7. The Following User Says Thank You to gubigfish For This Useful Post:
    threedogs (23rd November 2016)
  8. #467
    The new bar
    I have front points for other 4x4s that have 25 mm spacer
    with no problems they are held in situ via 3 x 10mm bolts
  9. #468
    Quote Originally Posted by gubigfish View Post
    Check Hodges build thread and see if you have the same set up.
    No one else does this set up so would like to keep it that way please
    email me at outback ideas at gmail dot com
    gubigfish (23rd November 2016)
  11. #469
    Oct 2010
    Old Bar, NSW
    Great stuff. Thanks John. The mounting looks substantial enough and the bolts are bigger so all is sweet.
    Macca
  12. The Following User Says Thank You to macca For This Useful Post:
  13. #470
    I think now the ones like hodge has now might suit yours better,
    you could sell your to GU bigfish if they are suitable, just a thought
