Hi Guys , I did the Super bright white park lights at front as pic shows , haven't been pulled over by police and lights work great in the daylight regards Alex
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
Thanks I cant see how making my patrol more visable is wrong.
But Ill stick to the plan if they are too bright I'll face them up a bit, lol\
Then again the rear dummy lights are illegal to I think, plan is to get
it up and on sometime this week end, need some 6 footers about 4
by tomorrow
I know the thread is 1yr old, but thanks 4bye4 for the details and instructions, I wired mine virtually identically.
I used these 4x of these @ ~$1.50ea: https://www.aliexpress.com/item/1Pcs...336903286.html
The aluminum backing allows them to be bent slightly so they're curved to the shape of the headlights and sit under the headlight protectors.
While the Ebay vendor sent me a NO rather than NC relay, the DRL's are wired pin 87A and works fine (until they send me the dedicated NC relays).
4bye4 (16th November 2016)
I have no way to measure if they are "more than 400 and less than 800 Cd" but they conform to the other legalities mentioned on the previous page.
They appear to be about the same brightness as what is seen on many newer Euro cars, in daylight they draw attention without dazzle, which is what they're intended to do.
