Page 4 of 9 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 88
Thread: 5,000 km and dead
  1. #31
    Legendary dom14's Avatar
    38 Post(s)
    Quote Originally Posted by UncleFrosty View Post
    Coupla hundred km (give or take) Perth to Brunswick @dom14!!!
    In Victoria, RACV Total care covers 100km towing and even more in country areas. I reckon with such a deal, you can pretty much cover the most cost of towing if not all.
    Few more mods on the way
    https://www.panthera.org/
    Cheetah Outreach
  2. #32
    38 Post(s)
    Quote Originally Posted by the godfather View Post
    Ended up costing me 380 to get it there. Original quote was 650.
    An to add to that, I am a sales rep on commission. So I am broke at the moment.
    On the up side work lent me an SS Ute with a 350 Chev in it
    Get a roadside assitance deal with an RACV equivalent in WA. It's money well spent, especially in 4WD'ing.
    Cheetah Outreach
  3. The Following User Says Thank You to dom14 For This Useful Post:
    the godfather (2nd November 2016)
  4. #33
    lets hope they get it sorted and don't try and charge you for it mate......... if it's something they did or didn't do, then I'd be asking for the freight money back too
  5. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    dom14 (3rd November 2016), the godfather (3rd November 2016)
  6. #34
    Expert the godfather's Avatar
    Mar 2011
    Piara Waters, WA
    Okay, I have had an update from Brunswick on my motor.
    For some reason (Unknown) the engine has over boosted.
    Not cause by the MAF.
    This has cause the head gasket to blow between two cylinders.
    Bottom end is fine, nothing wrong down there.
    So the engine is coming out, head getting faced or replaced.
    Dawes valve getting fitted, and EGR getting blocked.
    Is this warranty?
    Yes and no.
    Worst case scenario is 5k, which Brunswick are willing to split 50/50 with me. So 2.5k my cost.
  7. The Following 2 Users Say Thank You to the godfather For This Useful Post:
    Ropes (30th November 2016), Sir Roofy (7th November 2016)
  8. #35
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Good news that its recoverable mate. About the 50/50 bit hmmm! i don't know what discussions were held between you and Brunswck re the original motor, but seems a of a short life for a recon motor. Not knowing the full story it's hard to tell if its fare or not, but hopefully Brunswick realise that a lot of people read these forums and will have a think if they have a similar problem. I have always said that it is not only how good a job a company does, its how they react when it all turns to crap. In my own engineering business I have had to bite the bullet a couple of times when things went south and we couldn't identify a customer/operator error. I have to say that only happend twice in 25 years operating, but never the less i coughed up and fixed things at no cost to the customer other than freight.
    Just my opinion.
  9. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
    dom14 (8th November 2016), the godfather (7th November 2016)
  10. #36
    Mar 2011
    Piara Waters, WA
    I am sure I will be discussing more when it come time.
  11. #37
    38 Post(s)
    Discuss it beforehand. If there's no operator error(as 4bye4 explained above) the right thing for the repairer is to fix it at no cost.
    It's still gonna cost you anyway. The transport cost, time, the hassle of having to deal with the failure of newly reconditioned engine's failure, loss of work due to that, etc etc is costing you. If the "boost spiking" has nothing to do with the work they did on the engine, then they need to be able to explain it that it's not their fault.
    Cheetah Outreach
  12. #38
    38 Post(s)
    Is this warranty?
    Yes and no.
    Onus is on the repairer to ensure boost related components are finely tuned and checked, so the newly reconditioned engine doesn't end up getting blown less than 5000km after the job, and end up going back to them with more headaches. Repairer/mechanic is the expert, not you.
    So, based on the information given, it is a warranty issue, 'cos the part that is blown is a part they repaired.(Newly installed head or head gasket blows & no recognizable operator error was discovered)
    If you've had discussed to cut corners with the repairer during the engine rebuild job, then the warranty conditions were compromised. Something like that happened to me while ago, where I cut corners by not pressure testing a cylinder head with a head rebuilder & he managed to miss a visually obvious crack by missing to repair the crack. Head rebuilder was happy to repair the crack again and resurface the head for me in my case, 'cos it was visually obvious crack(the excuse of no pressure test was done wasn't a strong argument in that case). The downside for me was the head getting machined again meant the combustion chamber compression going tad higher than for my liking. I decided not to resurface the head & opted for an off the shelf chemical solution, 'cos I believed the crack wasn't that deep. The head is still going good after four and half years, and I learnt my lesson not to cut corners with important things, even when the finances are tough.
    Cheetah Outreach
  13. The Following User Says Thank You to dom14 For This Useful Post:
    the godfather (8th November 2016)
  14. #39
    Aug 2014
    Kingsley WA
    15 Post(s)
    Any news on this? @the godfather
  15. #40
    Mar 2011
    Piara Waters, WA
    Quote Originally Posted by 4bye4 View Post
    Mo mews. No resolution yet really.
    I spoke tot hem mid week and they said 3 weeks before I see it again
