Results 1 to 10 of 1356
Thread: All Things Chev
Threaded View
    Quote Originally Posted by rainsey View Post
    Totally different question. Any one put a hydraulic winch on their 6.5 using a separate hydraulic pump? Curious where the pump has been put.
    Rainsey
    Sent from my iPad using Tapatalk HD
    Rainsey, further to my previous note about the hydraulic pump location, my plans to run off the PTO have hit a snag due to the PTO being upside down and the ultra tight location. I have decided to revert to the belt driven assy and have made a plate bracket that mounts on the drivers side of the motor with the pump sitting over the top of the lower radiator hose. I will post up some shots when its assembled. There is a bit of jinking around to sort out the hoses and expense also - circa $400 just for them, so have to get it right. Once I get this operational I will investigate and resolve the PTO option, probably with a different pump that can give me the flow at lower revs to the one I have.
    rainsey (10th November 2016)
