Page 172 of 220 FirstFirst ... 170171172173174 ... LastLast
Results 1,711 to 1,720 of 2192
Thread: AB's new GQ is finally here
  1. #1711
    All good mate, I was thinking the same restricting vacuum causing built up pressure, restriction, etc...
    Thanks Matty!
    It will just be like your current system. It will pull a vacuum until there is no air left then the pump just continues to free spin until there is a differential again from something like a brake application. So just blanking the engine driven one will just means it will just be at absolute vacuum all the time. It wouldnt be hard to T it into your current system though.
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    MB (31st October 2016)
  3. #1712
    Yeah we were talking about that which is easy to do.
    I rung every single wrecker and parts supplier today trying to find the oil feed line and the vac line...zero!!!
    Looks like a tight fit running a braided line on the block side of injector pump, very, very tight with the pump and engine mount.
    I'll hook it up and see the best route but may be easier to run it on outside of injector pump back into block.
  4. #1713
    It will be easy.
    Get the fittings for the block and vac pump like I told you. Then measure from the seat of the fitting in the block to the centre of the fitting in the vac pump. Also measure the distance from the block to the block fitting and the distance from block to vac pump fitting seat. With this info get pirtek to make you a 1/4" tube to these dimensions.
  5. The Following User Says Thank You to nissannewby For This Useful Post:
  6. #1714
    22 Post(s)
    The vac pump is coming with all the vac hoses, just not oil. I wrongly assumed that would have come with the block
    96 GQ coil/Cab
    08 G6eT
  7. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (3rd November 2016), Woof (2nd November 2016)
  8. #1715
    Awesome, thanks Benny!!!
  9. #1716
    Hooray!!!
    The vac pump turned up, thanks Benny!
    I'll connect it tonight, work out exact route and fittings for oil feed then cross fingers for start up this Saturday!
  10. The Following 11 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (2nd November 2016), gubigfish (2nd November 2016), jay see (2nd November 2016), Maxhead (2nd November 2016), MB (2nd November 2016), MudRunnerTD (2nd November 2016), Rossco (2nd November 2016), rusty_nail (2nd November 2016), Stropp (2nd November 2016), Winnie (2nd November 2016), Woof (2nd November 2016)
  11. #1717
    Don't hate Matty but I'm running the oil feed on the outside of the injector pump....lol
    The inlet on the vac pump is on the right, little zig zag over the engine mount into a 90 bend to block.
    Yes, paranoid AB but I don't like braided line rubbing or severely close to block.
  12. The Following 4 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (2nd November 2016), mudski (2nd November 2016), rusty_nail (2nd November 2016), Stropp (4th November 2016)
  13. #1718
    Vac pump on, cover gear on, engine has now been built!!!
    Well, everything I can do outside of the vehicle.
  14. The Following 13 Users Say Thank You to AB For This Useful Post:
    Bacho86 (3rd November 2016), BigRAWesty (3rd November 2016), gubigfish (3rd November 2016), jack (3rd November 2016), Maxhead (3rd November 2016), MudRunnerTD (3rd November 2016), NissanGQ4.2 (3rd November 2016), Rossco (3rd November 2016), Sir Roofy (3rd November 2016), Stropp (4th November 2016), TPC (3rd November 2016), Winnie (3rd November 2016), Woof (3rd November 2016)
  15. #1719
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Well done mate, you've put some hrs into this thing now. Hope for a good install mate and of course a good PARTY!
    Good luck for the weekend
    ________________________
    ______ 2017 D-Max _______
  16. The Following 3 Users Say Thank You to Maxhead For This Useful Post:
    AB (3rd November 2016), BigRAWesty (3rd November 2016), Stropp (4th November 2016)
  17. #1720
    Your obsession with braided hose worries me lol. I wanted you to do it in tube not hose. It would have never rubbed and routed the way I said very neat.
  18. The Following User Says Thank You to nissannewby For This Useful Post:
