Page 3 of 64 FirstFirst 12345 ... LastLast
Results 21 to 30 of 634
Thread: Turbo Upgrades for the GUIV TD42Ti
    176 Post(s)
    @Hodge do you have a bigger Turbo on yours mate?
    Hey Daz.
    No mate. The only upgrades I have are the CC intercooler/scoop and a JPC high flow water pump all with a good tune.
    But,as per my previous post I am watching the thread with much interest!
    Also, I will add, the CC intercooler tamed the EGT's big time and gained a couple of ponies with it too. Pricey, but good investment.
    Have you also considered a bigger air intake ?
  2. The Following User Says Thank You to Hodge For This Useful Post:
    MudRunnerTD (1st November 2016)
  3. #22
    333 Post(s)
    Hey Daz.
    Hi mate, no I haven't considered intake mods really. I have a billet air box lid with a cobra head which I got off @Stropp when he upgraded his airbox. Stropp did you do your airbox upgrade as a stand alone mod? Did you notice a huge change? What snorkel have you got feeding it?
    Eric what sort of power did you make with your tune?
  4. #23
    333 Post(s)
    I think a bit over 2k for the BW Dazz plus a couple or more hundred for t5 adaptor, larger actuator, short bracket and other goodies so more on the 2.5k mark.
    Can you help me with a parts list and where to get all that mate. When the time comes I need to not loose any time parked up as it's the Daily for Naomi and I can afford to not have everything I need to bolt up and go.
  5. #24
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    PM already sent for 4.3s possible off mate Daz!
    Hi daz my diff / diff gears are of my 2.8 litre and are 4.625:1 the 4.375:1 gears you are after are from the 3 litre autos
    Cheers Kimbo
  6. The Following User Says Thank You to Kimbo63 For This Useful Post:
  7. #25
    333 Post(s)
    Quote Originally Posted by Kimbo63 View Post
    Cheers Kimbo
    Thanks Kimbo. You should get good coin for the 4.6s mate, everyone wants them.
    Kimbo63 (1st November 2016)
  9. #26
    Sure no probs
  10. #27
    176 Post(s)
    I went up from 75kW to about 100kW with just a tune after fitting a 3" exhaust.
    Then after fitting the CC intercooler they easily reached 115-120kW, but apparently the car was gasping for air at that stage or beyond.
    The standard HT18 was at its peak range so they suggested if I want more, I'd need a better turbo and/or open up the air intake.
    The IP was also a limiting factor.
  11. The Following User Says Thank You to Hodge For This Useful Post:
  12. #28
    When you do this work Darren I would suggest to take it to diesel tech for a tune up. I don't think the tune you had was very good.
  13. The Following User Says Thank You to Winnie For This Useful Post:
  14. #29
  15. The Following 2 Users Say Thank You to AB For This Useful Post:
    Hodge (1st November 2016), MudRunnerTD (1st November 2016)
  16. #30
    Just make sure you get 38mm bolt spacing for the oil drain and gasket.
    I think I also have a set of M8 x 1.25 studs too.
    Then Pirtek is your new friend in plumbing it up and I can help you there too with exact fittings and lengths, etc.
  17. The Following User Says Thank You to AB For This Useful Post:
