Page 14 of 16 FirstFirst ... 1213141516 LastLast
Results 131 to 140 of 154
Thread: Robo's ride
  1. #131
    Mar 2015
    no worries and good to see another coastie on here i'm at wyoming
    I never go into the outback with out a decent supply of water,
    and the general rule for how much you'll need is three litres
    per day , per person, per man per degree over 25 degrees
    celcius, per kilometer if walking on foot, in the winter months
    dividing it by two, plus... another litre... at the end .... Russell Coight
  2. #132
    Hardcore
    central coast nsw
    Quote Originally Posted by Makka View Post
    Wyoming my old stomping grounds.
    Grew up in Narara.
    The good old days you could walk the streets at night without a worry.
    Many a fri,sat night walk hick stagger home from Gosford leagues or bowling club 5k to home and never a problem.
    Don't think I'd try it now!
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  3. #133
    Mar 2015
    It's not to bad robo I got the bronks across the road had no real issues except one night a scumbag was picking on 3 12 year olds they ran onto my veranda I let them in and had a deep and meaningful discussion with him.... He told me I better watch out he just got out of jail...... I told him I'm not twelve and not scared of him .... He walked
  4. #134
    Hardcore
    central coast nsw
    Decided to spoil Pat with better radiator and braided lines.
    More like preventative maintenance coming up to summer hols and camping time.
    Brake safe being a sponsor here came to the rescue.
    DSCF9027.JPG.
    The brakes feel more responsive now & bit firmer pedal.
    I'm not over the moon about it,that said the calipers could use an overhaul as I doubt they have ever been apart.
    Weighing up to do calipers & new rotors, or complete new gear by replacing with tb48 stuff, will see.
    And Richard at ARE supplied the Radiator.
    well that's gotta be better than the piece that was in there lol.
    it holds approx 3.5 to 4 lts more coolant.
    ensure things stay in the green and I don't have to be gazing at temp gauge as much
    DSCF9030.JPG.
    Must say I was looked after very well by both shops.
    questions were answered and they followed up letting me know dispatch arrival times etc.
  5. The Following User Says Thank You to Robo For This Useful Post:
    MudRunnerTD (15th October 2016)
  6. #135
    Hardcore
    central coast nsw
    Giving the viscus hub a service.
    Completely drain and cleaned out old oil.
    Recon 50 mls is more like what came out, so in with near 3 bottles of 08816-10001.
    It's now a bit harder to turn by hand than it was before.
    I recon it now a little louder cruising so presume bit more air being worked by fan.
    Ambient air temp to cool to tell if its made any difference but next time vans hooked up will be the real test.
  7. The Following User Says Thank You to Robo For This Useful Post:
  8. #136
    Is that the Toyota part number Robo?
  9. #137
    Hardcore
    central coast nsw
    Didn't get a notification of your post/question, hence the delay to reply sorry mate.
    YES it is gen toyo p/No
  10. The Following User Says Thank You to Robo For This Useful Post:
    MudRunnerTD (27th November 2016)
  11. #138
    Hardcore
    central coast nsw
    New tridant hiflow tt2028-170 thermostat fitted.
    If you turn stat upside down and look inside the sensor you'll see 77degC stamped .
    It's the one listed in spare parts books as the correct one for mine as the alternative to the std one, and not a fudge
    Things are looking good n stable with normal driving.
    Now for a towing test.
  12. The Following User Says Thank You to Robo For This Useful Post:
    MudRunnerTD (1st December 2016)
  13. #139
    What is hiflow about it? Interested to see a pic. Im fitting a new water pump, coolan, fan and radiator on teh weekend. Not planning on teh thermostat but it seems a no brainer.....
  14. #140
    On the TDs Darren that bypass flap on the bottom of the stat lifts up higher than an OEM hence letting more water to flow quicker. In a nutshell.
  15. The Following User Says Thank You to mudski For This Useful Post:
