Page 16 of 35 FirstFirst ... 1415161718 ... LastLast
Results 151 to 160 of 341
Thread: Fund Raiser AB blew his engine
  1. #151
    22 Post(s)
    Yes mate we took all the head bolts out and missed the run up the middle. Farker wouldn't budge 😜 Rocker off in 30 seconds and we were all over it. Was a good day.
    Is the head to damaged to be reused?
    96 GQ coil/Cab
    08 G6eT
  2. #152
    Head looks good actually.. He should get it dressed and crack tested but looks viable.
  3. #153
    22 Post(s)
    Righto. It definatly needs to be checked, the correct sequence for loosening the bolts was ignored. Fingers crossed it's not warped.
    All of you own a manual
    96 GQ coil/Cab
    08 G6eT
  4. The Following 5 Users Say Thank You to Ben-e-boy For This Useful Post:
    Bigcol (30th September 2016), BigRAWesty (1st October 2016), growler2058 (1st October 2016), Rossco (3rd October 2016), rusty_nail (1st October 2016)
  5. #154
    i bet they never did a intro either
  6. The Following 7 Users Say Thank You to Avo For This Useful Post:
    BigRAWesty (1st October 2016), growler2058 (1st October 2016), Maxhead (1st October 2016), MudRunnerTD (1st October 2016), Rossco (2nd October 2016), Winnie (1st October 2016), Woof (1st October 2016)
  7. #155
    483 Post(s)
    Righto. It definatly needs to be checked, the correct sequence for loosening the bolts was ignored. Fingers crossed it's not warped. All of you own a manual
    Holy crap! For real? Rusty did (late arrival) mention knowledge of this from his old man's life lessons. Such knowledge, unfortunately out of our skills :-(
    No bullcrap, please do get your butts down here ASAP, my buy ;-) !!
  8. #156
    Cheers mate, yes we just stripped it off. Yes I didn't know that and yes Rusty did mention that. I really had zero expectation that this head would bolt onto anything without being checked and decked anyway. The valves need to be checked in #2 at least and probably worth re-seating them.
  9. #157
    Donated today Daz. Can't wait for this party!
    Gong him Red!!
  10. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    BigRAWesty (1st October 2016), MudRunnerTD (1st October 2016)
  11. #158
    G'day Mr Ben :-) (dbl thumbs up mate, apologies, no emojis thingo's on this Appy :-( )
    Do tell more, we need to learn ASAP !!
    I did bugger all mate no need to thank me!
    Sent from my BV6000 using Tapatalk
  12. #159
    I did mention there was an order lol, they didn't wanna hear it though
  13. #160
    It was a pretty big day yesterday, we got a lot done. None of us had ever taken an engine out before nor stripped one down to this degree.
    I've done a head gasket alone with a manual and certainly from go to whoow straight by the book. If this was a head gasket job then the service manual would have been open on the battery for sure!
    But, it's a pretty Big But, THIS THING IS FARKED!
    here are some pics I took yesterday. This engine has experienced Catastrophic Failure. I can't imagine using anything on this engine again without forensic testing to confirm viability. She is knacker led gents.
    Some pics!!
    Yes that is a Masdive hole on the block Behind the Brand new 12mm pump!!! Only the mounting bracket of the pump saved it from direct impact! Bloody lucky!! There is damage on the back of the pump mount!!
    The failure was in #2 piston and the Conrod disintegrated and blew out both sides of the block parallel with the crank. It also spat forward into the big end bearing on #1 and blew out the left side of #1 too!!! The Crank has taken significant impact. The Piston is molten and Gooorn!!
    The Conrod has spun empty on the crank and sliced a trench across the sump which is pretty cool too.
  14. The Following 7 Users Say Thank You to MudRunnerTD For This Useful Post:
    Bigcol (2nd October 2016), Clunk (2nd October 2016), mudnut (1st October 2016), Sherro (2nd October 2016), taslucas (2nd October 2016), TPC (3rd October 2016), Woof (2nd October 2016)
