OK. Only have a couple of picks of Turbo bolted to Chinese made Stainless steel Manifold. Kinugawa Turbo 0012.jpgKinugawa Turbo 0016.jpg
Have since thrown this manifold in with the scrap. It was badly distorted before I fitted it, both the face to head and also face to Turbo. Even though I shaved it on the mill, it couldn't cope with the heat and had too much trouble with it leaking. Ended up fitting a cast iron DTS manifold and even though it was $530, I now have no issues with any leaking. Having said all this about the Chinese manifold, and I wouldn't recommend anyone buy and fit one, part of the heat (too much) was I hadn't upgraded my exhaust to an unrestricted type. If I had done this before changing manifolds, I may have been able to retain the Stainless manifold, but I doubt it. Stainless steel doesn't conduct and cope with heat anywhere near as well as cast iron. The stainless manifold definitely had a lower engagement (1200rpm approx) due to smooth finish internally, compared to the Cast Iron which is 1600rpm. This is good and bad both ways, but Stainless/1200rpm was a bit too touchy for my liking, but I will say the economy seemed better. Best economy I can get with Cast Iron manifold is 400ks per 90 litres LPG. Stainless I could get 425ks per 90 litres LPG. Mind you this is trying hard/not sticking the boot in, only when some slow fart gets the better of me.
So at the end of the day if anyone wants to turbo their TB42E, I highly recommend it!
If I did it again, I would consider either making my own manifold from steam pipe or buying one from the guy who I think is in New Zealand and advertises on Ebay. Kinugawa Turbo I am very happy with also on ebay, but need to get the right model Turbo to suit TB42E. Was just looking for invoice and also looking on ebay to see if I can find model/type I used, but can't be sure. If anyone wants to know, I am sure i can find it, or email Kinugawa and ask which one they suggest. DTS manifold is a low mount rather than high mount stainless (as per photo).
Only issue I have now is engine mounts, which I am planning to check tomorrow. Have already replaced one a while ago, and I am pretty sure one or both has failed again. Just can't cope with the torque, so going to see if i can fit some TB48E mounts as they should handle the increased torque.
Although I don't visit this forum often, might add some more pics next time I am on. Happy to answer any questions, but might have to be patient for an answers
