Also, if you don't mind, what adhesive did you use to glue the carpet to your roof and pillars?
Did you glue, or use the same glue,on your door cards?
Why did you screw the roof lining to the roof. You just laid the carpet on the sound matting didn't you? I mean that you didn't make a board or card to stick the lining to first and then screw that to the roof.
Have you made some sort of padding on the sides and the cross members on the roof or is that the lining just straight on?
From the picture it looks like it is bulkier than just going over the sound padding.
Sorry for all these questions.
I do like your build log though and it is quite inspiring.
It is also sort of sad that it finished.
It is like watching your favourite TV show. You know it has to end sometime but it is still sad when it does. 😂
