You should weigh your axles front and rear, armed with that go to an 4x4 shop
with that knowledge and accessories fitted like dual battery, bull bar and winch
The drivers side is slightly longer to compensate for the driver, different spring mobs
may have a different formula to work out whats required. you may need 150lbs in the front
and 200lbs in the rear.
You would need to communicate with the vendor what your intended use would be.
They are pretty good these days matching up coil springs @the evil twin would know
