Results 1 to 10 of 33
Thread: Wiring/control for dual alternator setup in patrol
Threaded View
  1. #13
    Expert Arfa Brayne's Avatar
    Jul 2016
    Have you done that mate?
    I'm pretty excited about this possibility, 'cos i tend to carry extra cranking battery or two for this purpose.
    Can you please post bit more information about it?
    Thanx
    This is a very old trick, going back to the early 1970's. There have been a raft of "welding alternators' and even prior to that I believe there were generator units set up for welding. I have personally used 3x different ones, but they were all 24v.
    The amperage needs to be higher than a proper welder to help hold the arc, and they spatter a bit more too.
    General consensus is not to weld for longer than 20 seconds in every 2 minutes to allow for cooling.
    One was a 240 amp unit on an old 4 tonne International truck in the NT (almost as good as a proper welder)
    One, on a Case tractor in VIC, and the 3rd was a bush welder cobbled together from 2x 24v alternators and a Briggs 12hp engine
    The dedicated alternators have terminals on the back for welding leads and are massive bloody things. The bloke with the Inter would isolate the battery when welding to get a stable current and protect the batteries.
    I keep 1.5mm rod in the toolbox (it's a bit hard to get, but not uncommon) which seems to work ok with 12v x 80a, but is much better with 2x batteries in series as 24v. Just use jumper leads for welding leads. Soot/smut up some sunnies with candle smut for welding glasses, or carry a welding mask glass in the toolbox.
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
  2. The Following User Says Thank You to Arfa Brayne For This Useful Post:
    dom14 (15th September 2016)
