Page 19 of 98 FirstFirst ... 1718192021 ... LastLast
Results 181 to 190 of 972
  1. #181
    Yeah like that idea, seen it before and works quite well. . What about checker plate ally as another option. . .
    Flat alloy is ok but will blunt knives quickly.
    Check will be a biatch to clean.
    the good thing about ply and laminex is its dam cheap..
    So after a few years if it's scratched and hammered then it doesn't hurt the pocket much to simply bin it and start again..
    476 Post(s)
    BigRAWesty (15th September 2016)
  4. #183
    Jusy saying instead of caging in the fridge with box section and mesh,
    just use some ARC fence panel very strong and extend it so you have a top shelf.
    Good to see the Arthurmobile back where it belongs. lol
    or take some mesh to a sheetmetal place and get them to fold you a piece,
  5. #184
    I was thinking check down so the smooth side was up. Usually use a chopping board or plate when chopping stuff but laminex does sound good. Used 9mm ply with a bit of carpet on mine, doesn't work too bad. . .
  6. The Following User Says Thank You to Rossco For This Useful Post:
  7. #185
    You could use a thin sheet of teflon which would be cool too. Easy to wipe down and doubles as a chopping board itself.
  8. The Following 3 Users Say Thank You to Winnie For This Useful Post:
    BigRAWesty (15th September 2016), mudski (15th September 2016), threedogs (15th September 2016)
  9. #186
    Yea a bit of 12mm nylon sheet with a few stays either side..
    Heaps of options..
    I like the marble laminex though..
    Adds class lol
  10. The Following User Says Thank You to BigRAWesty For This Useful Post:
  11. #187
    On the other one [4x4] I used honeycomb wall partition from an aircraft [flip down table]
    and glued a piece of aluminium sheet to it and then edged it with alloy angle iron.
    Hand some cable lanyards made to hold the table when down and held it shut with 2
    ute tie downs,
    When the table was down I had access to my minibar/spice rack, I hollowed out the big
    door and made a box with shelves to fit inside, It mainly held UHF milk, coffee, tea,
    sugar and an array of different spices , the smaller door I hollowed out and fitted
    my thomas copressor , That was over 20yrs ago now but still a great idea I thought at the time,lol
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #188
    476 Post(s)
  14. #189
    476 Post(s)
  15. #190
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Just trying to figure out how to hide these holes now. The paint work their is a bit how's ya going too. I'm thinking a stainless plate laser cut into something?
    Attachment 68963Attachment 68964Attachment 68965
    I want to remove the two front flares too and clean them out and drill some large drain holes in the base on them too.
    Bit of weld, bog and rustoleum paint and you can't go wrong ha ha
    Sent from my E6653 using Tapatalk
    Lucus30's 1999 GU ST TB45E
  16. The Following User Says Thank You to lucus30 For This Useful Post:
    mudski (16th September 2016)
