Results 1 to 5 of 5
Thread: Accessories behind drivers side dash? GU
    Aug 2016
    Evening guys, I'm installing boost/pyro gauges in the A pillar, have used the dimmer switch for gauge light power( blue and black stripe wire and pink for earth) and the lights work fine, I need acc power for the pyro gauge is there an easy place to find it? As in locally behind the dash? There are a million wires back there and I'm to lazy to search! Thanks in advance
    176 Post(s)
    Easiest is probably to use a piggyback fuse holder & take the power from an accessory fuse.
    http://www.ebay.com.au/itm/New-1X-AT...gAAOSwdIFXydk5
    Available in mini & standard blade fuse size
  3. The Following User Says Thank You to Cuppa For This Useful Post:
    macca (11th September 2016)
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Hard to work with wires under the dash. Easier to pull the radio out and find power from there.
  5. The Following User Says Thank You to Covo71 For This Useful Post:
    Oct 2010
    Old Bar, NSW
    Accessory socket is also a good supply that's relatively easy to get to.
    Used to be called cigarette / cigar lighter, when did that change? LOL
    Interesting find @Cuppa
    Macca
    Dec 2015
    WA
    5 Post(s)
    Cigarette lighter is what we use when installing 2 way radios (we actually use it to switch a relay direct from battery).
    Graham
