Page 47 of 52 FirstFirst ... 4546474849 ... LastLast
Results 461 to 470 of 517
Thread: Blocking the EGR Valve
  1. #461
    Feb 2011
    Shed
    45 Post(s)
    Ordered a 3" S/S zorst for my DX, Ive got the EGR blanking plate in already. Im sure i read somewhere that i may now over boost even with the CRD. Is that right. Stooooopid search function is doing my head in! Do i need to fit a dawes valve? Am i gunna get error codes now? I got a scan gauge 2 so can clear if they come up. Should i be fitting pyro and boost gauges now, baring in mine the scan gauge shows boost
  2. #462
    Yep I had issues on the highway with over boost when coasting..
    Around town want an issue.
    Just coasting was seeing up to 30 psi
  3. The Following User Says Thank You to BigRAWesty For This Useful Post:
    growler2058 (7th September 2016)
  4. #463
    Feb 2011
    Shed
    45 Post(s)
    Bummer
  5. #464
    Did you not see this then boyo?
    http://www.nissanpatrol.com.au/forum...ad.php?t=38321
  6. #465
    May 2016
    lower west victoria
    30 Post(s)
    I fitted a blanking plate a week ago. No codes.
  7. #466
    What boost are you getting
    I thought a 10mm hole in the EGR plate stopped any issues
  8. #467
    Not all CRD's get the limp mode or CEL issues for some reason. Much like the Tritons, its anyones guess.
    threedogs (8th September 2016)
  10. #468
    Bummer
    Instead of buying a boost gauge cant you
    hook up a temp gauge just to see what yo're getting
  11. #469
    Feb 2011
    Shed
    45 Post(s)
    Yeah i will definitely get temp gauge
  12. #470
    May 2016
    lower west victoria
    30 Post(s)
    How can I tell what boost I'm getting? I have no additional guages.
    I thought fitting a blanking plate didn't cause any issues except getting error codes on the dash occassionally.
