Page 150 of 220 FirstFirst ... 148149150151152 ... LastLast
Results 1,491 to 1,500 of 2192
Thread: AB's new GQ is finally here
  1. #1491
    Above level mate but thanks for asking any questions mate as i am losing my ship with reasons.
    No one way valve just hose mate but my next step is getting the correct oil drain fitting although supplied the incorrect one to begin with.
    I have gone too far and may be chasing my tail but we saw oil coming out of turbo with no oil drain at all, just into container whilst engine running but could've been oil residue sitting in turbo already from past tests which is frustrating.
    Here is a clear tube pipe installed test and its flowing.
    http://youtu.be/LUwiSzxdV84
    Oil from turbo...I'm solo here so video is crap
    http://youtu.be/bEXliAD9Juc
  2. #1492
    Fwiw in the drain video. This is a clear tube, once oil hits the wall of clear tube it stays.
    At the bottom is the oil hitting the barb so small amounts will come back "coating" the clear tube. That is not full of oil sitting at bottom, nor is top part either as you are seeing oil "splashing" "swirling" from the turbo.
    However, oil drain fitting from turbo incorrectly supplied replacement is close to my last resort to be honest.
    In fact, if that fails I have no idea what to do next?
  3. #1493
    Does your oil return above or below the sump oil level? Do you have a one way valve in the drain line? Does it even need one I dunno. But could it be back flow up your oil drain? Sent from my SM-G925I using Tapatalk
    Also, no you don't need a one way valve. You just want oil to flow the quickest way possible with as much volume you can give mate.
  4. The Following User Says Thank You to AB For This Useful Post:
    sooty_10 (4th September 2016)
  5. #1494
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Jesus Christ mate ! I hoped after our conversation the other day that you'd have got some direction from the turbo guru but obviously it continues 😩
  6. The Following User Says Thank You to Sprock For This Useful Post:
    AB (3rd September 2016)
  7. #1495
    Checked out fine mate which in my position was very disappointing lol
  8. #1496
    22 Post(s)
    So what was the compressed air test outcome
    96 GQ coil/Cab
    08 G6eT
  9. #1497
    Perfect, as per the video...
  10. #1498
    Expert JonnoD's Avatar
    4 Post(s)
    That really sucks mate. Mine hasnt been driven since that trip either so I feel your pain
  11. The Following User Says Thank You to JonnoD For This Useful Post:
    AB (4th September 2016)
  12. #1499
    Jun 2015
    Heyfield Vic
    35 Post(s)
    That sucks big hairy balls mate
  13. #1500
    That sucks big hairy balls mate Sent from my iPhone using Tapatalk
    All good mate, i may have an answer soon when I get back to Vic!
