Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 65
Thread: Warn Winch Service Manuals 6k to 12k
  1. #31
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    @oncedisturbed Hi Jase whats the difference between the XD and the XP is it just motor size ??
    To be honest, not entirely sure but I believe it is motor / gear variations between the 2.
    I can't even remember what model mine is lol
    Never underestimate the power of the tap, let it flow through you.
    www.swat4x4.com
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    It is literally the 6hp motor. The xd has a 4.6 and xp has 6hp. Gearbox ratios are identical and drum diameters are the same etc.
    I now run a 6hp warn motor on my xd9000. Required modification to the bullbar mount to fit between chassis rails and other wise was direct bolt on.
  4. The Following 2 Users Say Thank You to sooty_10 For This Useful Post:
    MudRunnerTD (2nd September 2016), threedogs (2nd September 2016)
  5. #33
    Wheres the best place to buy new rope these days?
    You can buy 30mtrs for around $119. thats about the cheapest Ive seen it.
    I have DYNEEMA which I brought off Big Balls when Liam had helm.
    Not sure if whats out there is as strong Dyneema but the properties are similar
    from memory I have 12mm on the winch drum x 30mtrs
    http://www.ebay.com.au/itm/X-BULL-Dy...8AAOSwzLlXgw~u
  6. The Following User Says Thank You to threedogs For This Useful Post:
    mudski (2nd September 2016)
  7. #34
    I think Ill hang my 30mtrs of winch cable up in Man Land
    so ppl can see how it used to be done in the old days.
    I originally had it made up to showcase a device for holding cable
    on your back door, @MudRunnerTD may remember them , the ones
    I saw were mainly on short 40s and made by Kaymar.
    Ive been fabricating gear for a long time. lol
    @sooty_10 I can remove my winch from the front but I needed to space the winch up
    when they fitted it , it was way too low for the hawse fairlead outlet
  8. #35
    Found a pic from one of @MB posts, you could buy these cable holder
    that would fit to the RWOD similar to a Hi-lift jack, ,was a safe way
    to carry spare cable, as I said Kay mar sold them,it was for 5/16 swr
    not so much the Tirfor cable, Ill drag mine out later, I made a heap of things to
    hang off the rear door with the wheel lol
  9. #36
    Synthetic. I replaced the wire rope to save weight ages ago. From memory taking it off & replacing the rollers with an alloy hause was worth over 13 Kg.
    You could use a block and tackle from a roof beam, bit of overkill
    but it will get it out for you, or hire an engine crane lol
  10. #37
    174 Post(s)
    I have received a PM from a member with the same vehicle & bullbar & winch that I have & he tells me that even with the splash guard removed from the bottom of the bullbar that the bullbar still needs to be unbolted & partially removed to get the winch in & out. Unfortunately with a clearspan style shed the roof beams are beyond my reach. If I do the job I'll have to build something to support the bullbar & winch. Thats a lot of stuffing around just to re-grease something.
  11. #38
    I had a Nissan bar previously with my guiv before my little crash and had my winch fitted to it. I definitely did not need to unbolt the bar. It's a bit of a bugger but I fitted and removed a couple of times my winch from my Nissan Factory bar alone in my driveway without any ropes.
    I would be very surprised if you hade yo take the bar off.
    Although.... That would make the whole thing really bloody simple @Cuppa! The factory bar is easy to unbolt. You could lift it off with the winch pretty easily mate. Unbolt and slide out.
  12. #39
    Go to your local all tools or bunnings and buy a 2000kg sling for $20 or less. Tie it to your rafter at a convenient location and hang a block and tackle from it. In my old shed I left the sling in place permanently and just used a shackle to hook on a half ton block and tackle. Winner mate it will be bloody handy for you.
  13. #40
    Bendigo
    7 Post(s)
    What bullbar is it @Cuppa ? Any of the factory nissan ones I've ever seen definitely didn't need bullbar removal. May be different with a td42ti and the tall radiator.
