Sweet, thanks.
I cant do till friday, i let ya all know how i go.
Seal both end of the ic up with duct tape or the same. Then submerse the ic in water with the inlet and outlet above the water, then use a bike pump with one of those ball pump needle thingo's and push it through the tape and pump air into the ic. If you see bubbles then its leaking. Or just take it to a radiator mob....
You need to do one thing at a time otherwise you will just get lost in it all. Make sure the ic is good then move onto the next thing. Resetting the dawes and needle valves.
