Page 300 of 570 FirstFirst ... 298299300301302 ... LastLast
Results 2,991 to 3,000 of 5693
  1. #2991
    Sure its not the panhard bush at the chassis end?
    Nope its like a spinning rubbing sound.... not a knock and besides, panhards are less than a year old, or whenever I got them from you, and have done virtually stuff all offroading since fitting them
  2. #2992
    Spinning rubbing sound? Hmm...
  3. #2993
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    Keyless entry showed up today. But I think the wifey wants to put it away for the kids to give me for fathers day.
  4. The Following 2 Users Say Thank You to Covo71 For This Useful Post:
    mudski (24th August 2016), threedogs (24th August 2016)
  5. #2994
    Not the exhaust rubbing on the cross member, only spinning rubbing sound I have atm lol
    I take it yours is a manual???
  6. #2995
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by Covo71 View Post
    Attachment 68762
    New wiring for the lights at the back. Will have both brake lights again. Thanks Mark.
    Hey is that a kit to put rear lights where there aren't rear lights but should be rear lights?
    If so, how much?
  7. #2996
    If so, how much?
    They are the OEM looms that are used for the bumper lights on the GQ mate. They often get cooked by the exhaust on one side and ripped out on the other. Lol.
  8. #2997
    Dec 2012
    Coffs Harbour
    As mudski said it is the Wiring looms for the brake lights/ blinkers in the bumper bar. Mine had rusted the bulbs in tight.
  9. #2998
    Yes, I'm thinking possibly drive shaft rubbing on something, or possibly even fan rubbing..... cant see any sign if either though..... so left side engine mount first, then drivers side, then maybe gearbox mount
  10. #2999
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Have you tried cleaning the MAf? Maybe disconnect the battery for a couple of hours and see if the problem goes away
    ________________________
    ______ 2017 D-Max _______
  11. The Following 3 Users Say Thank You to Maxhead For This Useful Post:
    Clunk (25th August 2016), Kimbo63 (25th August 2016), mudski (25th August 2016)
  12. #3000
    Fan belts worn??? Pulleys worn?
