Results 11 to 20 of 29
Thread: RB30-RD28 T gearbox compatability.
    80 Post(s)
    After reading up on the RB30 in the article that is posted in the helpful hints thread, it was mean't to be a glorified shopping trolley. It is a shame they had that mindset as a low first gear would have made the RB just as good as the TB.
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    Yep, that is disappointing. The RB30 is a good engine and runs so smoothly, with smooth gear changes too.
    It might feel a bit strange on the road with a lower first gear, but it would help for off road for sure, sometimes I still have to ride the clutch a bit on rocks in 1st low or risk stalling...
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  4. The Following User Says Thank You to Patrol'n For This Useful Post:
    mudnut (10th August 2016)
  5. #13
    80 Post(s)
    The other thing is hill descent. If you aren't on the brakes the engine runs away, which is a bit dangerous.
  6. The Following User Says Thank You to mudnut For This Useful Post:
    Patrol'n (11th August 2016)
  7. #14
    Oct 2014
    WA
    That's so true, I do find that the engine braking a tiny bit more effective once my revs hit about 3000rpm, and then there is some engine braking although nothing like a diesel engine. I also find if I turn on my air conditioning, I get a bit more engine braking effect since the engine isn't quite as willing to rev with the aircon on. I must admit that I am a little (ok VERY) cautious about muddy descents where brakes are not a great idea.
    I would consider reduction gears in the transfer case except that with the limited power of the RB30, I find I need to use low range quite often in soft sand (there's a lot of sand over here in WA), and then I wouldn't go anywhere at any kind of acceptable speed. Although I have been trying to resist modding the engine, I'm still thinking turbo conversion and reduction gears, guess I gotta start saving. Probably cheaper to buy a different vehicle, but I do love my truck...
  8. The Following User Says Thank You to Patrol'n For This Useful Post:
    mudnut (11th August 2016)
  9. #15
    80 Post(s)
    The best mods I have made are taking the heater grid from under the carby, blocking the stove pipe diaphragm (in the warmer months, for long trips and water crossings) and fitting headers. The engine is still a bit asthmatic so I am toying with the idea of enlarging the neck of the filter housing. All this has made the engine rev a lot easier and has not been too expensive. I am hoping the RD gearbox has a lower first cog, so if that is available I would fit that to the gearbox while it is apart.
    It seems that no one has the answers we seek...
  10. The Following User Says Thank You to mudnut For This Useful Post:
  11. #16
    Oct 2014
    WA
    Yep that is what it seems. I have the basic things covered as you have, and I have been told that fuel injection improves it too, but also means peak torque is achieved higher in the rev range, which doesn't sound like a great idea... if you do enlarge the neck of the filter housing and it makes an improvement then I'd love to know what you did so I can give it a shot too.
  12. #17
    80 Post(s)
    There's two ways I think it could be done. Split the neck 20mm off to the side of the Pre-heat flap and weld in a strip top and bottom, or add a hose from the plastic pipe to the side of the filter housing.
  13. The Following User Says Thank You to mudnut For This Useful Post:
    Patrol'n (12th September 2016)
  14. #18
    80 Post(s)
    Could someone with an RD28t please post up the transmission number on the ID plate?
  15. #19
    Beginner UWN717's Avatar
    still have gearbox mate wats ur location?????
  16. #20
    Patrol Guru sooty_10's Avatar
    Bendigo
    7 Post(s)
    I'll try to remember and check the one I have in the shed.
  17. The Following User Says Thank You to sooty_10 For This Useful Post:
    mudnut (11th September 2016)
