I would check to make sure that the battery is touching the contacts in the remote properly, and that the contacts are clean and have enough tension. Check the battery voltage and see if it actually is low.
I would also try a second battery, and check it for the correct voltage with a multimeter before you install it, and see if it does the same.
Then you will definitely know what to do next.
