Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Rear Door Table
    Thats real neat. Best is that they are close to me. Worst is that it may be a little too thick and might hit my drawers....
    Its only 25mm when folded,,,,, at a guess Id say it fits,,
    no-one has drawers that close to the rear doors,,,,,,do they
  2. #12
    Jul 2015
    Camden NSW
    6 Post(s)
    I measured mine and it's 35mm clearance. If your drawers are located on the floor as close as possible to the rear doors, I think about 35mm is the norm in GU's. One thing you need to check is the thickness of any draw handles you may have. That could be an issue for some if you have a draw on the RHS.
  3. The Following 2 Users Say Thank You to bazzaboy For This Useful Post:
    jay see (3rd August 2016), threedogs (3rd August 2016)
  4. #13
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Quote Originally Posted by bazzaboy View Post
    It's such a great idea, you've convinced me to do the same. Just ordered a black one. It looks like it's fitted with a tube light, if so, I may change it to an LED strip. Does the light have a switch?
    When you trimmed the bottom of it, did you do just the RHS edge to clear the raised door opening plastic trim, or the full bottom edge?
    Ok bazzaboy here we go.
    1. The lights are LEDs
    2. The light dose have a switch on the right hand inside edge.
    3. I needed to take 20mm off of the bottom edge plus the far left end of the bottom from the left edge 75mm in, a further 15mm. So 75mm from the left in I took off 35mm and the rest of the bottom only 20mm to fit the mouldings in my car. Now I don't know but I would say there may well be slight differences in some models so you would have to measure and double check yours. Hope I've explained that well enough mate.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  5. The Following User Says Thank You to Chubba For This Useful Post:
    bazzaboy (4th August 2016)
  6. #14
    476 Post(s)
    Yeah 25mm, it wont fit. The top edge of the drawers will touch.
