Results 1 to 10 of 14
Thread: Rear Door Table
    Patrol Guru Chubba's Avatar
    Oct 2013
    Adelaide
    5 Post(s)
    Rear Door Table
    Put this in the other day and must say I'm bloody happy with it. My brother Pat found it on eBay under caravan accessories and being the top bloke that he is, bought me one too. Made to fit to the outside of a van but fits perfectly on the barn door. Has it's own light as well $174
    It's a stainless steel table top but I've left the film on.
    Just needed a slight modification at the bottom for clearance when the door is closed.
    Over all a neat tidy mod to the car.
    Had one small problem fitting it though. One of the drill holes for the screws went straight into the wiper motor. Didn't find out for a couple of days when it rained and the wiper didn't work. Thinking bloody what now, I had a flash and realised what I had done. Unbelievably though I just pulled the screw out and it worked again.
    98' Ti, 4.5L, 2" lift, factory rear diff lock with front E-locker, 63% reduction gears
    "GO YOU CROWS"
  2. The Following 13 Users Say Thank You to Chubba For This Useful Post:
    abw (31st July 2016), bazzaboy (3rd August 2016), BigRAWesty (31st July 2016), caveman21 (2nd August 2016), gaddy (31st July 2016), growler2058 (31st July 2016), jay see (1st August 2016), mudski (1st August 2016), NissanGQ4.2 (4th August 2016), Roosim (1st August 2016), Stropp (2nd August 2016), TPC (31st July 2016), Woof (31st July 2016)
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    that looks nice as mate
    Expert Arfa Brayne's Avatar
    Jul 2016
    Very nice indeed.
    Was planning on making one form Alupanel, but your's is schmik.
    Do you have a link or address for the one you got ?
    "Can't" is a dirty 4 letter word.
    Best way to deal with a "Can't" is to chop off the "t" and brew it in boiled water for a few minutes.
    Sip on the "t", and consider what you've got left to work with
    Oct 2013
    Adelaide
    5 Post(s)
    I don't know the link mate but this looks like the table but the price doesn't look right. Pat told me $174 so just keep hunting around. Maybe Pats more generous that he's letting on...... I'll ask him today.
    http://m.ebay.com.au/itm/WHITE-Range...621?nav=SEARCH
    Hold the phone!!!!! I think I've found it.....
    http://m.ebay.com.au/itm/201634791692
    "GO YOU CROWS"
  6. The Following User Says Thank You to Chubba For This Useful Post:
    Jul 2015
    Camden NSW
    6 Post(s)
    Nice unit. Could you please give me the OD measurements?
    Jul 2015
    Camden NSW
    6 Post(s)
    Guys,
    If you search Ebay for "Caravan Picnic Table BLACK" you will find this unit. Would be nice if they stated the OD size & thickness.
  9. The Following User Says Thank You to bazzaboy For This Useful Post:
  10. #7
    Oct 2013
    Adelaide
    5 Post(s)
    Quote Originally Posted by bazzaboy View Post
    This is from the site.
    Specifications:
    Dimension(mm): 800 x 450 x 25
    Weight: 5kg
    Capacity: 30 KG
    Only available in white
    Easy to use keyless double slide opening mechanism
    easy to clean internal stainless steel surface
    "GO YOU CROWS"
  11. The Following User Says Thank You to Chubba For This Useful Post:
    bazzaboy (1st August 2016)
  12. #8
    Unafordable
    4 Post(s)
    Nice find, I wish there was one around when I was doing mine. I found this tosser on Facewaste who wanted $400 for SS table and rear door splash guard/trim.
    I do like included LED lights.
    While mine was certainly cheaper to make it isn't perfect either so sometime professionaly made things with reasonable price tag are worth the $$$ and not the backyarder hassles.
  13. The Following User Says Thank You to Rumcajs For This Useful Post:
    Chubba (1st August 2016)
  14. #9
    Thats real neat. Best is that they are close to me. Worst is that it may be a little too thick and might hit my drawers....
  15. #10
    Jul 2015
    Camden NSW
    6 Post(s)
    It's such a great idea, you've convinced me to do the same. Just ordered a black one. It looks like it's fitted with a tube light, if so, I may change it to an LED strip. Does the light have a switch?
    When you trimmed the bottom of it, did you do just the RHS edge to clear the raised door opening plastic trim, or the full bottom edge?
