24th July 2016, 03:41 PM
Patrol Guru
Noise after fitting new Alternator Belt
Comes from the front of the motor sounds like a squeak noise, could it be the new belt rubbing on something? Or is it likely something else? Its a 2004 4.2TDi.
Fish
24th July 2016 03:41 PM
24th July 2016, 11:14 PM
Too much or too little tension on the belt?
The Following User Says Thank You to kroggy For This Useful Post:
gubigfish (25th July 2016)
25th July 2016, 07:14 AM
Patrol Guru
Is it a squeak or a squeal and does it stop after a while?
The Following User Says Thank You to Irish For This Useful Post:
25th July 2016, 08:42 AM
Patrol Guru
Its not a squeal but more of a squeak but you can hear it when shes idling, haven't check to see if it goes away after a while. I'll take her for a drive this arvo and find out if its stops after a while.
25th July 2016, 06:57 PM
Try squirting a little crc on either the ac bearing or tensioner bearing..
If it's still there spray the other..
If it's still there it's your belt..
The Following User Says Thank You to BigRAWesty For This Useful Post:
