I thought I should pass on my experiences solving a similar prob on my dual fuel TB4.2E GQ. The story began when I ran on gas for ages, keeping almost no fuel in the LRA petrol tank. Then came the day I ran out of gas, switched to petrol as I drove and had the 4.2 trying to conk out on me as I put my foot down. With much backfiring and lurching, I got to a servo, put in more petrol but the prob remained the same. Gas ran no worries, but petrol switchover at idle led to the 4.2 trying to conk out, with very careful nursing of the go pedal keeping it going. On the freeway, a switch from gas to petrol was possible, but the 4.2 felt underpowered, and any sort of accelerating led to a 4.2 liter hissy fit. The problem turned out to be the fuel pump. I didn't realize that the in tank type of pumps rely on the fuel in the tank to keep them cool. When I dropped the tank, the pump/sender assembly came out easily and I saw the rubber base the pump sits on was melted looking. The LPG conversion had led to the LRA petrol tank being used, and the in tank pump was replaced at that time. The dodgy el cheapo crimping connectors that connected the pump leads to the original in tank pump wiring were, in a word, shitful. It never ceases to amaze me how blokes spend big bucks on after market stuff, but the wiring seems to be consistently crap. So - I got a new Goss pump (GE132), and soldered new wires from the lugs on the underside of the fuel tank sender cover, new terminals soldered on the ends of the wires where they bolt onto the pump, put it all together again, put fresh fuel in the tank, started on petrol first time and it runs sweet. Low fuel had cooked the old pump. Even though it was running, the delivery was marginal and heavy acceleration took more than it could provide, which is why there was much crappy running on petrol. I suspected the fuel pressure regulator initially, which is the little can at the front of the injector rail - but a swap showed that it was not that. The pump wiring was so poor, there was no way I could not fix that up as it was a breakdown waiting to happen. Lessons are: 1) don't let petrol level get too low - the pump will cook and 2) do good wiring or don't do it at all.
