Page 676 of 1057 FirstFirst ... 674675676677678 ... LastLast
Results 6,751 to 6,760 of 10561
  1. #6751
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Check the EGR pipe as well for splits, they squeal like a stuck pig
    Unless already blocked
    Yeah I've read that , it will be blocked at both ends by the time I'm finished so that'll eliminate that pipe out of the equation , it's already blocked at the valve end but the pipe WAS still under pressure but not anymore , I was just going to block the manifold end of the EGR pipe and put it back together but while I've got it disassembled this far I thought I might as well pull a manifold off and put new gaskets on it as well . Can't see any soot leaks around it but it wouldn't take much of a leak to make a noise .
  2. #6752
    Jun 2015
    Heyfield Vic
    35 Post(s)
    BREAKTHROUGH !!!!! Leaking around the front of the manifold , what an absolute poofter of a job that was - getting the oil & coolant lines off the turbo - the bloke that designed all that obviously never had to work on it , then get the little front heat shield off & then I found the leak .
  3. The Following User Says Thank You to Sprock For This Useful Post:
    BigRAWesty (22nd July 2016)
  4. #6753
    475 Post(s)
    Ya fixed it yet?
  5. #6754
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Just heading in to get the manifold gasket now , I'll start on it this arvo & probably finish in the morning , feel free to pop around & offer technical advice mate . You could also WATCH me drink stubbies 😝 Drank 5 last night pulling the turbo & then the manifold off 😏
  6. The Following User Says Thank You to Sprock For This Useful Post:
    BigRAWesty (23rd July 2016)
  7. #6755
    I thought it was at least a 7 stubby job lol
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6756
    Jun 2015
    Heyfield Vic
    35 Post(s)
    So you've worked on a zd30 before then ? 😝 I worked fast lastnight 👍🏼
  10. #6757
    475 Post(s)
    Dunno whats worse.
  11. #6758
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Haha sorry mate 😩
  12. #6759
    Jun 2015
    Heyfield Vic
    35 Post(s)
    So Mudski it turns out that NOBODY in the Latrobe Valley stocks a manifold gasket for a ZD30- NOBODY . 😤 So I Ordered it in for the morning ......... So I guess I'll just sit here & drink inside 👍🏼
  13. The Following User Says Thank You to Sprock For This Useful Post:
  14. #6760
    Expert rusty00's Avatar
    Jun 2015
    South Eastern VIC
    Caster correction and spacers to push the diff forward.
    I can now have mud flaps with the 33s
    Drives a treat too.....
    2012 GU8
  15. The Following User Says Thank You to rusty00 For This Useful Post:
