Results 1 to 5 of 5
Thread: Squeaks from engine bay, advice sort.
    Oct 2014
    Newcastle
    Hi fellas,
    The CRD 3L Patrol has now done 127,000 kms and the engine bay has developed a squeak when the motor is running. Does this sound like the idler pulley on the belt tensioner is about to fail? If this is the case, is the remedy to replace the belt tensioner assembly and the belt? If so how difficult a job is it?
    Michael
    2008 GU DX Auto, dual batteries, Safari snorkel, Warn winch. Engine standard CRD 3L
    Also check the clutch pulley on the alternator
  3. The Following User Says Thank You to threedogs For This Useful Post:
    micknor51 (21st July 2016)
    177 Post(s)
    The most common issues for your symptoms is the idler pulley tensioner thingamajig.
    Not a hard job to replace. Use only genuine gear, as all others are well known to develop issues again.
  5. The Following User Says Thank You to Hodge For This Useful Post:
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Yep sounds like it. Mine was especially bad on cold starts early in the morning, but it has been running well since I had it replaced - apparently they're known to only last around 120-130k if you're lucky
  7. The Following User Says Thank You to Bacho86 For This Useful Post:
  8. #5
    Oct 2014
    Newcastle
    Thanks threedogs, Hodge and Bacho86 I'll get to it with genuine Nissan bits.
    Michael
  9. The Following User Says Thank You to micknor51 For This Useful Post:
    BigRAWesty (22nd July 2016)
