Results 1 to 10 of 16
Thread: Help needed wiring Switch and Relay for work lights
Threaded View
  1. #12
    Quote Originally Posted by DaveGQ View Post
    I have the same setup as described by the original poster. Trouble is I am running 2 x 55w Spot Halogen lights and the factory wiring from the reverse light isn't adequate. The lights are noticeably dimmer when powered by the reverse wiring.
    I am not very savvy when it comes to electrickery and would appreciate some help (in layman's terms) how I can solve the issue. Obviously I need to use a relay, but how do I wire it?
    Here is the caveman setup I currently have. Feel free to scribble on it and post back! Thanks
    Gday mate,
    You need to fit a relay into your system. Use the linked supply from your reverse light to the Trigger 86 on the relay. Decent power fused from your battery to 30, Earth to 85 (85 and 86 can go in either direction) and 87 to your reverse light.
    If you want to add a switch to the back so you can switch it on from the back too then add a switch into the 86 pin doubling it up and draw the power to that from the power from the battery i.e. pin 30 to your switch. Note if you have a reverse camera it will turn on with the switch as will your reverse lights.
    ice-cube-iso-relay-Wire-diagrams-easy-simple-detail-baja-designs-electric-relay-wiring-diagram.jpg
    DaveGQ (23rd July 2016)
