Page 13 of 98 FirstFirst ... 1112131415 ... LastLast
Results 121 to 130 of 972
  1. #121
    177 Post(s)
    Very Nice Mark.
    Will have to pop around and have a gander at these. Whens the fitting.
  2. #122
    Safari do a 4" ram head but its around 130-150. If you have dremel go and get a 2mm end mill. They go straight in the dremel chuck and you can cut any which way as long as you have a steady hand. Otherwise grab yourself a nibbler or cheap air hacksaw.
    As for the comp cover and as I said earlier just leave the 3" inlet one in place. Just use a short 3-4" straight adaptor in silicon this will be fine.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    mudski (15th July 2016)
  4. #123
    Part 2/3 has arrived.... <img src="http://www.nissanpatrol.com.au/forums/attachment.php?attachmentid=68157"/> I'm think to maybe even get a 4-3 adapter for the box to intake pipe fitment, put the snorkel and box in, and then do the rest when I get the comp housing.
    Did you specifically order it with the piping on the snorkel side or is that how it turned up?
  5. #124
    I'm sure MB wouldn't mind you borrowing the nibbler mate or bring it over one day and I'll cut it for you.
    I've cut a few now, nothing better then cutting someone else's panels
  6. The Following User Says Thank You to AB For This Useful Post:
    BrazilianY60 (27th April 2023)
  7. #125
    476 Post(s)
    AB (15th July 2016)
  9. #126
    The comp cover on it is 2 3/4 not 3 Mat. The GT3071 only has two inlet options. Neither are 3inch. Ill stick with the Donaldson head as Hitachi near by sell them for about $60. And i might get the mill end bit for my dremel... The air box was just the air box and nothing else. The snorkel came with all the bits needed to attach to the air box. Sent from my SM-P600 using Tapatalk
    Yeah ok, interesting they now supply a pipe to connect rather then a rubber flange.
    I'm glad they listened to customer feedback
  10. #127
    476 Post(s)
  11. #128
    Come on mark.... just get a 4"- 2.75" reducer then. Simple.
  12. #129
    476 Post(s)
  13. #130
    Which part are you refering too? The pipe from the snorkel to the elbow into the air box? Sent from my SM-P600 using Tapatalk
    Yep that part, the pipe on the airbox intake
  14. The Following User Says Thank You to AB For This Useful Post:
    mudski (16th July 2016)
