Page 21 of 77 FirstFirst ... 1920212223 ... LastLast
Results 201 to 210 of 762
Thread: Jay see 1997 GU build up
  1. #201
    After the mothers club meeting was over at pro axle they got into fitting the offset kingpin and doing the wheel alignment, even took off the steering wheel to have it straight.
    Don't think that it has ever felt this good in the steering before.
    Would recommend as guys any day. Cheers Mudski for the head up.
    Sent from my XT1068 using Tapatalk
  2. The Following User Says Thank You to jay see For This Useful Post:
    mudski (14th July 2016)
  3. #202
    You don't have an adjustable drag link John? Bring a six pack over, we'll share it, and you can have one I got here sitting around doing nothing. Lol. I bought it from RooDogs about 18months ago. Its a heavy duty one. Well heavy for them.
    Proaxle tried to talk me into those offset bearing but I'm not sold on them so I left it at that. He does plenty of Patrols there so he's pretty thorough in what he does.
    jay see (15th July 2016)
  5. #203
    No mate don't have one.
    The adjustable link helps with toe in/out correct?
    The offset bearings are to correct the camber.
  6. #204
    Drag link goes from steering box to swivel hub. Adjustable items allow you to re-centre the box which then centres the steering wheel.
    The tie rod which joins the 2 swivels hubs (on the rear side of front diff) is what you adjust to alter your toe.
  7. The Following User Says Thank You to nissannewby For This Useful Post:
  8. #205
    So in my case is a adjustable drag link needed if all it does is recenter the wheel.
    I went for the offset bearings because it was chewing out the outer edge on the front passenger.
  9. #206
    Yep just an adjustable drag link. Moving the steering wheel on the spline with a 2" lift is ok. Always best to adjust drag link if possible. Anything over a 2" lift an adjustable drag link is a must.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #207
    Didn't need much was only one spine. So if I do get the drag link should I put the wheel back and then adjust?
  12. #208
    I think I will take you up on that offer @mudski. Everyone always says that at 2" lift you don't need things like offset radius arm bushes, adjustable panhards and drag link, but without them I would be scrapping at full lock, my diff are out between 5-10mm and the steering out by one spine.
  13. #209
    how do you find out where the center of the box is mate? im fairly certain i need to recenter mine, i have the adjustable link just have nfi how to work out correct adjustments lol
  14. #210
    177 Post(s)
    Is this pro axle in campbellfield ?
    I took my Patrol there for an alignment and I got sent home.
    He told me because I just have a basic 2" lift kit he can't align it.
    I need an adjustable this and an adjustable that.. I forgot exactly which parts but yeah .
