Page 871 of 1467 FirstFirst ... 869870871872873 ... LastLast
Results 8,701 to 8,710 of 14662
  1. #8701
    Thats bad mate. Jetstar did that to the mrs once but luckily only a 2 hour wait til the next available flight. Dodged a bullet on that one. He you get home ok today.
    yeah were back and at work now. was a shitty night sleeping in the airport lol
    Shame mate, you should've driven back here?????
    would have loved to mate but we had returned the car already =( least were home now
  2. #8702
    Patrol Freak Touses's Avatar
    Mar 2016
    Childers QLD
    22 Post(s)
    Im about 99% sure this is something no male could achieve....
    When she hits menopause it becomes a mutual understanding. Eventually you forget just who ties up who! Bahahaha
  3. The Following User Says Thank You to Touses For This Useful Post:
    nissannewby (14th July 2016)
  4. #8703
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Mate, they're out there.
    >>>tappin from tassie
    Hello from Under Down Under!
  5. #8704
    Been standing out the front of pro axle for 20 minutes wait for them to start on the patrol.
    They're having a mother's club meeting with some bloke.
    Sent from my XT1068 using Tapatalk
  6. The Following User Says Thank You to jay see For This Useful Post:
    rusty_nail (14th July 2016)
  7. #8705
    Patrol Freak garett's Avatar
    Jan 2015
    north
    21 Post(s)
    What year 323?
    its a 1996 1.8L... been stuffing with the idle screw and o2 sensor. but should have test values tomorrow.
  8. #8706
    I wouldnt touch the idle screw it should be controlled by the ecu. I would be checking sensors and wiring. We recently had issues with our 01 323 which was a failed knock sensor. You can flash codes out of these easy enough as well.
    This is all assuming it is fuel injected.
  9. #8707
    Jan 2015
    north
    21 Post(s)
    yep fuel injected nope no codes been there already, trying to make the idle bypass work in a different rage to see if it has a bad spot. but saw a steady stream of bubbles coming out the rad over flow bottle.... oh and the hunting is intermittent and only happens when you slow and stop 3 or 4 times...
  10. #8708
    Well what a farked trip..
    So car hit limp mode.
    Adelaide hills, 19 psi boost, just breaking 400c egt, fuel was about 20L/ hour but that's normal..
    And it just hit..
    Fuel shot to 35L/ hour, and she died..
    Tried the foot off reset but no good..
    Had to pull over and shut down..
    All good.. next will, 5th again but 100k/h this time..
    Same thing..
    So pull over, reset..
    Got threw the hills by knocking back to 4th for the inclines..
    I'd assume the ecu is cracking the shits as it'll be wanting to knock back boost and increase fuel for the hills..
    But tillix is holding it at 19..
    So I'm going back to 16 psi today..
    See how it goes on the way home..
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Australia Post the biggest threat to onlone trading in Australia.
    Started
    Processed through Australia Post facility
    7:42am Sun 10 Jul Chullora, NSW
    Previous event
    Started
    12:02am Fri 8 Jul Underwood, QLD
    Previous event
    Started
    In transit
    5:08pm Thu 7 Jul Kuraby, QLD
    Previous event
    In transit
    Picked up from sender
    3:26pm Thu 7 Jul Underwood, QLD
  12. The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
    BigRAWesty (15th July 2016), jack (15th July 2016)
  13. #8710
    And it just hit..
    Same thing..
    Code found..
    P0234
    Over boost..
    So backed down to 15.5..
    See how it goes..
    Seriously considering throwing the stock ecu controller back in but having the tillix limit the over boost by bleeding into vac system..
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
    growler2058 (16th July 2016)
