Long story short. 2000 ZD30 went in for a tune and came out with new engine when a cylinder was found to be weak. New motor was left stock until warranty ran out. Had a Dawes Valve and a Catch can fitted and now the workshop can only set Max Boost to 10psi and it still has an overboost problem. Will go into limp mode in 4th and 5th gear 23-2450rpm under moderate acceleration blip the throttle and it rectifies itself. Egt's are running no higher than 450-500° running at 105kph uphill. This motor has a Redback 3"straight through exhaust and a larger intercooler which were fitted prior to replacement engine with no overboost issues. Workshop never fit a EGR blanking plate as I'm only going to do 15-20,000km before moving the vehicle on and they have had issues with ZD30 over boosting with a blank plate fitted. Apart from the overboost issues Dawes control for the turbo has made the vehicle much nicer to drive. Pre dawes my boost was all over the shop with erractic and potentually dangerous EGTS (600+°). What could be causing this boost issue??? Workshop says my vehicle is worst they have seen. Normally they set max boost at 14-15psi post dawes fitment without an issue. Mine is set at max of 10psi and still has issues? Hope my rambling makes sense any help is greatly appreciated. The workshop is talking about fitting a "fuel cut defender" for extra cost of course to sort out this issue.
Cheers guys.
