jay see (5th July 2016)
Fatz Air box and a Radius Snorkel. Then a 4inch intake for the 3071 soon. The one Ben gave me is a no good.
Rossco (7th July 2016)
Mine didn't have the anti surge. To be honest I don't even know what or how the anti surge will affect my setup, plus I dont really want to go changing this as it drives fine now, its just sucking air through a straw though right now. The wheel size is larger to suit the housing Ben gave me. Only by 1mm but, knowing my luck, I will just root something if I change too much. Getting housing with the everything the same, just the intake diameter different seems easier.
Bene also said to me a week or so after the meet down here, he wasn't confident that this housing will work on my turbo too. But it might. I asked MTQ, gave them all the specs on mine and even they didn't really want to say yes.
I'm at your peril Matty. Whats your thoughts with this housing? I haven't ordered this part yet. I don't know anywhere near enough to go buggerising around changing turbo bits mate.
I just thought to simply change over the housing to the larger intake and thats it.
Hey Mat. Do you know the Cat part number for the battery that fits under the bonnet of the GU? My battery is stuffed, I rang CAT and the guy I spoke to was piss farting around with batteries not even close to what would fit. Looking at their website and no wonder, its one page per battery so it takes for ever to look though their range.
Anti- surge wont effect anything. A/r wont effect is operation but will allow a little more volume for a given psi. If the wheel is 1mm smaller then it wont work. Clearance has to be less than 0.010".
Just run 4" all the way from airbox to turbo and just use a short 3-4" silicon joiner at the turbo.
BigRAWesty (10th July 2016), mudski (7th July 2016)
