Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Water gets in when it rains??
    May 2016
    iv got a 1998 TI 4.5L
    every time it rains i get a foot well of water on the passenger side looks come out of the black ducking under the dash but im not sure
    is there a seal inside the vents up top from the out side intake vent? just want to get it fixed
    cheers
    matty
    Last edited by NissanGQ4.2; 24th March 2018 at 04:53 PM. Reason: Fixed spelling in title
    Expert Mike02Ti's Avatar
    Jun 2016
    Rockingham WA
    4 Post(s)
    Being a TI have you got a sunroof? Maybe the drain hose is blocked that runs down the A pillar or there may be a hole in it somewhere
    2002 GUIII Ti 4.8
    Details here
  3. The Following User Says Thank You to Mike02Ti For This Useful Post:
    mattyk (4th July 2016)
    May 2016
    yes sunroof as well, i didn't think there was a drain down the pillar somthing i,ll look closer into
    just every time it rains i see it dripping off the black air ways box under passengers dash side,
    Jun 2016
    Rockingham WA
    4 Post(s)
    Definitely check it out. There is one on each A pillar. If you tip water down them it should come out under the car around the front wheel area and hopefully not inside your car.
    Hope your ti is parked inside somewhere if your in Melbourne...
    Sent from my XT1068 using Tapatalk
  7. The Following User Says Thank You to jay see For This Useful Post:
    BigRAWesty (5th July 2016)
    How is your windscreen seal? Check the bottom corners.
    Expert Bloggsy's Avatar
    Perth WA
    A couple of places to check.
    1. Grill panel under windscreen (outside) is held on by some scrivets (or whatever they are called). I believe these sometimes these go walkabout especially if the windscreen has been replaced at some point. Make sure they are not missing, especially the end one on the passenger side which seals the hole that sits right above the air ducting intake.
    2. Also make sure the A/C drain (on the firewall I think) is not blocked.
    I hope this helps.
  10. The Following User Says Thank You to Bloggsy For This Useful Post:
    mattyk (5th July 2016)
  11. #8
    What Bloggsy said X 2
    If it only happens when it rains it is a good chance it is the Scrivets in the Scuttle Panel.
    If you reach up and the joiner in the duct is dripping then make that 95% chance
    If the Windscreen has been replaced make it 100%
  12. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    mattyk (5th July 2016), mudski (24th March 2018)
  13. #9
    Even the top part too.
    The join of my rubber is at the top corner DS and I get water in the footwell, runs down under the trim of the A pillar onto the floor.
    Killed me for weeks trying to find that leak as it was hidden behind the vinyl.
  14. #10
    May 2016
    yeah it leaks in the one join in the black ducting under the dash,
    the windscreen was replace late last year
