Page 19 of 77 FirstFirst ... 1718192021 ... LastLast
Results 181 to 190 of 762
Thread: Jay see 1997 GU build up
  1. #181
    Cheers Hodge.
    Any info is good info..
    Think I'm just over thinking things.
    Sent from my XT1068 using Tapatalk
  2. #182
    Cant you space the front diff 12mm forward to prevent this happening.
    Heard or read something about it
  3. #183
    Patrol Freak Bacho86's Avatar
    Mar 2011
    14 Post(s)
    Think this would definitely be overdoing things IMO - fit the new tyres on first and if required trim / remove front mud flaps
  4. #184
    I was at my folks place last night and was flicking through the local paper and saw ad for a tyre place in South Morang rang them up this morning and was quoted 1900, asked if they could do 1800 and if they had them in stock. Yes and yes.
    Did a few tight u turns and no robbing at all😂. This is will the wheel turned. It may be due to the 2 degree offset brush.
    One concern I had was in the wet, well today was a good day to test them, drove a bit harder into the corners around home and I'm impressed.
    Drivers side.
    Passenger side.
    Slight difference that adjustable panhards will fix, but it's not much do that can wait.
    Tried to get a wheel alignment at pro axle for today, but they're full, will try for another day asap.
    Cheers everyone for the input.
  5. The Following 7 Users Say Thank You to jay see For This Useful Post:
    AB (5th July 2016), Bacho86 (5th July 2016), MB (5th July 2016), Mike02Ti (10th July 2016), mudski (5th July 2016), Rossco (5th July 2016), threedogs (6th July 2016)
  6. #185
    Mar 2011
    14 Post(s)
    Good outcome mate, nice work!
  7. The Following User Says Thank You to Bacho86 For This Useful Post:
    jay see (5th July 2016)
  8. #186
    Aug 2014
    Perth
    10 Post(s)
    $1800 just for tyres or was that Rims as well?
  9. #187
    1800 for 4 ROH 16X8 -13 with 305/70/16 BFG KM2s.
  10. The Following 2 Users Say Thank You to jay see For This Useful Post:
    gubigfish (5th July 2016), Mike02Ti (10th July 2016)
  11. #188
    And it even throw my speedo back to only 2ks out.
  12. #189
    Betcha you dying to test these babies out, I take it they are nice and quiet ATM.
    what pressures are you running or going to run
  13. #190
    177 Post(s)
    Toolangi and dissa are nice and greasy right now if you're keen to take the shine of the new rubber.
