Results 1 to 10 of 18
Thread: Towbar receiver pins
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    I have noticed a few towbars fitted with a recovery hitch using a locking retainer pin. Good for security, but . . .
    The pin in my towbar is clearly stamped '1012' which is a carbon steel considerable better performing in this role than mild steel.
    After looking at a few locking retainer pins, I have not seen any that are stamped or with any indication of their strength.
    Seems like a potential weak point, but does anyone know enough metallurgy to tell me if a strong pin is really required?
    Thoughts?
    Ive rang a few tow bar manufacturers years ago asking for a rating on the pin.
    All requests came back blank and all pins had no rating, Still very easy to bend
    a pin with a strap on it..Bugger to get out to.
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Brissieboy (4th July 2016)
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    They are unlikely to bend with the recovery hitch or the tow hitch inserted as it will be mostly shear forces in play.
    Not so with a strap directly onto the pin though. Not a fan of that idea, but heaps better than the ball.
    I would assume that the pin would not be the weakest point in a recovery hitch setup, but would like to be a little more confident.
    Ever heard of a pin failure?
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    I have seen and done many snatches over the years and we always use only the pin at the rear. I have never seen one bend. What are you doing to make them bend? If you are putting that much force on it maybe you should not be snatching. Maybe you should be winching instead.
  6. The Following 2 Users Say Thank You to BillsGU For This Useful Post:
    MudRunnerTD (5th July 2016), Rossco (5th July 2016)
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Never had a bent one either - I can just see the potential to bend one. Never seen a damaged one either, but was just wondering about the possibility of damage when I noticed that mine was stamped and the locking ones were not.
    Sorry if it is a silly question but just thought I'd ask the experts here.
    Not a silly question mate at all. I have never seen one bend ever. Done some big snatches off on too. I have also had a rated hook shear during a snatch and go through the fuel tank of the tow car. If it's a big snatch winch out.
    Ive never bent one just a story Ive been told
    Clunk (5th July 2016)
  11. #8
    Also had a snatch block basically explode during a Triple line pull!!
    Might have been a little bogged!
    Here's a good one!! Would you recover off this hook!!!!
    taslucas (5th July 2016)
  13. #9
    @MudRunnerTD That red hook should of had a gusset plate welded on the underside of the bar, But that was then eh
    remember those washers ARB welded on the front of their bars cause the eyelets were ripping open.
    Better to grind them off altogether plus some pre air bag bull bars had the facility to bolt some
    black hooks to them as well, these too needed a gusset plate minimum 6mm .
    We have come a long way since then though and hopefully common sense takes over,
    as the recovery gear improves , but this is only about the tow pin eh.
    Ive also found after buying over 5000 rated hooks,,,,,, that the chrome
    ones tend to stretch and break more than the black ones
  14. #10
    Like that time at band camp hey
