Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 77
Thread: Warn highmount rebuild kit
  1. #61
    Holy cr@p, @MudRunnerTD @Rossco TD:-) slight research extra now and my M/C just up'd and ran :-(
    It gets crazy quickly mate!!
    MB (1st July 2016)
  3. #62
    483 Post(s)
    @mudski says on another "Do it once & Do it right ;-)" Totally agree, personally have waisted too much muck around over the years and now need to prioritise to see more country safely :-) !!!
  4. #63
    i agree. You don't really need the air freespool for safety though mate. Its a nice bit of kit for sure but its more a Comp Scene kind of requirement. The Warn HiMount will spool out with your switches nearly as quickly as you can walk. I never use my freespool handle now. When i go out with the air freespool it will be awesome don't get me wrong, but it will basically let my Navi pull rope out without restriction and then i can engage the freespool from the cab when I'm hooked up. Without it i would just spool out. No big deal though to be honest.
    If i had to choose between a GP Brake Shaft and an Air Freespool my money would be spent on the GP Brake Shaft every single day mate.
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (1st July 2016), mudski (2nd July 2016)
  6. #64
    483 Post(s)
    i agree. You don't really need the air freespool for safety though mate. Its a nice bit of kit for sure but its more a Comp Scene kind of requirement. The Warn HiMount will spool out with your switches nearly as quickly as you can walk. I never use my freespool handle now. When i go out with the air freespool it will be awesome don't get me wrong, but it will basically let my Navi pull rope out without restriction and then i can engage the freespool from the cab when I'm hooked up. Without it i would just spool out. No big deal though to be honest. If i had to choose between a GP Brake Shaft and an Air Freespool my money would be spent on the GP Brake Shaft every single day mate.
    Cheers Daz, the safety I was hoping for was the wider drum with thinner core so I can fit plenty of 12mm rope on from your earlier advice, just a bonus I guess it comes with air actuation as standard :-)
  7. The Following User Says Thank You to MB For This Useful Post:
    MudRunnerTD (1st July 2016)
  8. #65
    Yeah as awsome as air freespool is, for our application certainly isn't needed. Spooling out with the motor is quick enough and in cab and buttons up front are great, definatly recommend these. More rope is a bonus, but extension strap if you need it or another length of rope with some spliced ends should deal with most situations. .
  9. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (1st July 2016), MudRunnerTD (1st July 2016)
  10. #66
    You can actually buy an extended drum without the freespool. Without the freespool you could make your own actually. Just cut and extend the drum centre and reweld. With the freespool you also get a roller bearing in the drum end (I had this already and it's now fitted to ABs (he did ok )
    @Winnie how much did you pay for your bearing end plate mod? Got any pics for @MB
    Just trying to save you some cash mate. Seriously consider the GP Brakeshaft though.
  11. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    MB (1st July 2016), Rossco (1st July 2016)
  12. #67
    I paid $50 to get my drum modified, I bought the modified end cap with the top hat and paid $100
    I'll chuck some pics up this arvo.
  13. The Following User Says Thank You to Winnie For This Useful Post:
    MB (1st July 2016)
  14. #68
  15. The Following User Says Thank You to Winnie For This Useful Post:
    MB (2nd July 2016)
  16. #69
    Ah, you've got the brace kit too. That's another thing to concider / throw more $$ at @MB
  17. The Following User Says Thank You to Rossco For This Useful Post:
    MB (2nd July 2016)
  18. #70
    Maybe should make a Warn Rebuild thread sticky or something. As one day, one day i will get a high mount and all the info posted in only two pages so far is priceless.
  19. The Following User Says Thank You to mudski For This Useful Post:
    MB (2nd July 2016)
