Page 6 of 8 FirstFirst ... 45678 LastLast
Results 51 to 60 of 77
Thread: Warn highmount rebuild kit
  1. #51
    483 Post(s)
    Cheers markie, yeah only joking mines still holding together plus we have learnt a few more tricks to throw @ yours. Haven't got long before i head off but may as well get yours together if the bits are all here soon. Have you got the cases sand blasted yet? Will need to get some paint, drain & fill plugs (m12) and a solenoid too at some stage and a switch. Pretty sure i have some breather line & fittings. Also we were going to get a newer style clutch lever handle thingy. . .
    Cheers Rossco, you've done more solo HC miles than almost anyone I know mate! No rush on the HM, stress less and enjoy your hard earned time up north with Sir Roofy&Jane !! No need I believe for handle thingy, air actuation on a wider drum will be enroute in the next few weeks:-)
  2. #52
    All good markie once all the bits are together won't take long to put it together, see how we go. . . You seriously going air freespool & +76 drum ?
  3. The Following User Says Thank You to Rossco For This Useful Post:
    MB (30th June 2016)
  4. #53
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Il be, Sir Roofy I like that , when next mentioning me just
    highlight my name
    Thank you my Loyal subjects
  5. The Following 2 Users Say Thank You to Sir Roofy For This Useful Post:
    MB (30th June 2016), Rossco (30th June 2016)
  6. #54
    483 Post(s)
    Thanks Rossco, yep, when you're back from the legendary adventure it would be truly appreciated to learn the finer seal skills etc...:-) Yep, Mr T has planted a sead for over engineering my non-comp toy. Being many years out of the HC exploration game and 40+ now I'm thinking about winching up anything past a blue run :-)
  7. #55
    483 Post(s)
    Quote Originally Posted by roofy View Post
    Il be, Sir Roofy I like that , when next mentioning me just highlight my name Thank you my Loyal subjects
    @SirRoofy or @roofySir @roofy damn techy stuff confuses me @AB alone ?
    Sir Roofy (1st July 2016)
  9. #56
    Hey Rossco sounds like you're getting a new air free spool for your winch! Mark won't know if you swapsie =)
  10. The Following 2 Users Say Thank You to Winnie For This Useful Post:
  11. #57
    483 Post(s)
    Happy to lend a drill and grinder for GQ bar to offset the +drum too :-)
  12. #58
    Oh man i would love one they would be epic!. . . I mean nah there not that good, I'll take it off your hands markie you can have my much better standard jobbie haha.
    Nah wow your not going to know this thing markie world's apart from a standard high mount. What bar are you putting it in, is it wide enough for the wide drum? ?
  13. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (30th June 2016), Winnie (30th June 2016)
  14. #59
    @MB nice one mate. Yes the answer is A Lot. I have driven with him though which helps a bit too mate. If your going a Deltatek Air free spool then happy days! You should also grab off him a Stealth freespool delete plate. Cheap and a great upgrade. I like the Deltatek over the Gigglepin air freespool as the DT has a smaller centre so will fit more rope.
    Ask Phil about an Allbright Solenoid pack and GP longer motor bolts to mount the Allbright.
    You should also consider a Gigglepin Brakeshaft. This is a Serious Upgrade. Probably the best upgrade available IMO. Fundamentally better. I Tapped and capped the Warn Brakeshaft which is not bad. ( this is now fitted to ABs winch) the GP Brake shaft is Epic! It's all money though mate. The circlip on the Brakeshaft is almost the weakest link and regardless you need to modify or replace.
  15. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    MB (30th June 2016)
  16. #60
    483 Post(s)
    Holy cr@p, @MudRunnerTD @Rossco TD:-) slight research extra now and my M/C just up'd and ran :-(
  17. The Following User Says Thank You to MB For This Useful Post:
